07-01-2015, 13:06 | #391 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: england
Member: 1798097 Status: Offline Thanks Meter: 86 | Quote:
there you go my friend Note4PersistWipe | |
The Following 5 Users Say Thank You to aryan cartio For This Useful Post: |
07-02-2015, 12:14 | #395 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | g925f ee disable hi , i'm tryng to remove "ee disable message. i manage to root and to write custom recoverty twrp but in recovery connect to usb run: adb device ok adb shell error D:\Gsm\Boxuri\htc unlock\platform-tools>adb shell CANNOT LINK EXECUTABLE DEPENDENCIES: library "libc.so" not found i want to try this solution For S6 : G920f Root with this file Root And install this recovery twrp-2.8.6.2 And use this command Code: adb shell dd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda13 |
The Following User Says Thank You to IM8 For This Useful Post: |
07-08-2015, 02:19 | #400 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | I'm curious why you're even concerned about tripping the warranty when the phone is already blocked. Would you be turning in the said stolen phone for a warranty repair? That wouldn't be wise... |
The Following 4 Users Say Thank You to ecs87 For This Useful Post: |
07-08-2015, 18:15 | #402 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 579082 Status: Offline Thanks Meter: 0 | Quote:
Thanks | |
07-08-2015, 19:35 | #403 (permalink) | |
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
Long story short, you're most likely not going to be able to accomplish what you want to unless you're a very skilled programmer. | |
07-09-2015, 07:56 | #405 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Toronto
Member: 2244501 Status: Offline Thanks Meter: 16 | Flash Cyanogen Mod to your phones, problem solved, no need to beg for some patchy solution |
The Following User Says Thank You to Hamzues For This Useful Post: |
