Galaxy j5 flash error system.img any ideas on how to flash this galaxy j5 ? Code: File analysis... Ok |
Hello the phone what error shows on screen when you get this error Sent from my SM-G935F using Tapatalk |
give serial number i will help you |
thank you for your support the phone showed " an error has occured while updating the device software, use the emergency recovery functions in the smart switch software." the phone showed this error in z3x and odin while putting it in download mode. when i let him write the firmware showing this message, it passed. |
now your mobile is working? |
Place the phone on dl mode and read pit with z3x it will boot up normally and flash 4 files firmware Quote:
sir can you help me this SM-G361F S/N R3VCJO18A8M IMEI 351718072778493 Thanks in advance.. |
[IMG]http://i66.tinypic.com/m97zq1.png[/IMG] |
anyway thanks... |
just try it |
almost a dozens of firmware i use to flash that phone but all are failed in system.img... some says hw problem maybe emmc ic or some says just repair efs but until no one can share good tested efs for that phone. except pre-rooted and repair 4 files all are ok in flashing but result is still system installing updating and erasing and reboot and reboot again. thanks sir..,we will fedback the result after.. |
Flash with odin .3.10 tested by me Also change data cable |
Will see with future phones |
