Old 12-11-2016, 09:45   #1 (permalink)
Member: 1816005
Thanks Meter: 236
Galaxy j5 flash error system.img
any ideas on how to flash this galaxy j5 ?
File analysis... Ok
Total file size: 0x873F7820 (2163 Mb)
Searching USB Flash interface... COM72 detected
Setup connection... Ok
Set PIT file... Ok
Reading PIT from phone... Ok
Sending aboot.mbn... Ok
Sending sbl1.mbn... Ok
Sending rpm.mbn... Ok
Sending tz.mbn... Ok
Sending hyp.mbn... Ok
Sending NON-HLOS.bin... Ok
Sending sec.dat... Ok
Sending boot.img... Ok
Sending recovery.img... Ok
Sending system.img.ext4... error
Done with Samsung Tool PRO v.27.4
Old 12-11-2016, 13:15   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,218
Hello the phone what error shows on screen when you get this error
Sent from my SM-G935F using Tapatalk
The Following User Says Thank You to souma_k For This Useful Post:
Old 12-11-2016, 13:26   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 916
give serial number i will help you
The Following User Says Thank You to kothamamun For This Useful Post:
Old 12-11-2016, 13:31   #4 (permalink)
Member: 1816005
Thanks Meter: 236
thank you for your support
the phone showed " an error has occured while updating the device software, use the emergency recovery functions in the smart switch software."
the phone showed this error in z3x and odin while putting it in download mode.
when i let him write the firmware showing this message, it passed.
Old 12-11-2016, 13:42   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 916
now your mobile is working?
Old 12-11-2016, 14:32   #6 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,218
Place the phone on dl mode and read pit with z3x it will boot up normally and flash 4 files firmware
Old 12-11-2016, 14:48   #7 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 74
I have also same problem..
sir can you help me this SM-G361F S/N R3VCJO18A8M IMEI 351718072778493
Thanks in advance..
Old 12-11-2016, 15:11   #8 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 916
Originally Posted by blaze25 View Post
i have also same problem..
Sir can you help me this sm-g361f s/n r3vcjo18a8m imei 351718072778493
thanks in advance..
flash this firmware problem will be solved
[IMG][/IMG]
The Following 2 Users Say Thank You to kothamamun For This Useful Post:
Old 12-11-2016, 15:17   #9 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 74
[IMG][/IMG]
where can you get that firmware sir,base on s/n or serial?..,because i try use that serial to kies and smartswitch and it says not found.
anyway thanks...
The Following User Says Thank You to Blaze25 For This Useful Post:
Old 12-11-2016, 15:20   #10 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 916
anyway thanks...
something secret so i can not explain
just try it
Old 12-11-2016, 15:30   #11 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 74
just try it
ok ill try it....
almost a dozens of firmware i use to flash that phone but all are failed in system.img...
some says hw problem maybe emmc ic or some says just repair efs but until no one can share good tested efs for that phone.
except pre-rooted and repair 4 files all are ok in flashing but result is still system installing updating and erasing and reboot and reboot again.
thanks sir..,we will fedback the result after..
Old 12-11-2016, 15:41   #12 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 916
ok ill try it....
after flash if problem still appear thats mean hadware issue
Old 12-11-2016, 16:56   #13 (permalink)
sweetsonu984's Avatar
Member: 1660122
Sonork: 100.1673803
Thanks Meter: 78
Flash with odin .3.10 tested by me
Also change data cable
Old 12-11-2016, 17:35   #14 (permalink)
Member: 1816005
Thanks Meter: 236
Yes now is working
Will see with future phones
Old 12-22-2016, 11:59   #15 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 74
i think its hardware problem flashing failed also with your firmware.
Page generated in 0.40492 seconds with 7 queries
