01-24-2017, 00:34 | #46 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | |
01-26-2017, 21:03 | #47 (permalink) | |
Junior Member Join Date: Jul 2009
Member: 1067092 Status: Offline Thanks Meter: 2 | Quote:
Samsung account and reactivation lock all gone..! Good luck and if you know finally about any free solution, please put it here for future references, we never know. At last thanks again for help and effort..! | |
01-27-2017, 00:54 | #48 (permalink) | |
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
01-30-2017, 01:55 | #49 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | Hello guys, I keep trying to remove the Samsung Reactivation (KK) lock. I installed the Combination files and selected the G920P model: UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G920P Software version: 27.7 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G920P" "Erasing FRP lock error" - Пошук Google Done with Samsung Tool PRO v.27.7 |
01-30-2017, 01:56 | #50 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | I also tried the G920V model: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G920V Selected port: COM8 USB Serial Port Software version: 27.7 Searching Samsung USB Flash interface... COM17 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G920V" "Erasing FRP lock error" - Пошук Google Done with Samsung Tool PRO v.27.7 |
01-30-2017, 02:52 | #52 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
Sent from my SM-N930T using Tapatalk | |
01-30-2017, 04:19 | #56 (permalink) |
Crazy Poster Join Date: Oct 2015
Member: 2475865 Status: Offline Thanks Meter: 15 | You can do it with two different options... 1. Flash combination firmware and add your dummy samsjng account, flash back to stock but it has to be 5.0, at the start process it will let you remove *Reactivation Lock* 2. Clone phone IMEI into a Galaxy S4 and remove it from that end and you will see remove the RL after performing a Hard reset ... |
The Following User Says Thank You to iDonTuseRubbers For This Useful Post: |
01-30-2017, 05:09 | #57 (permalink) | |
2. This I have not tried it yet. Do you mean that i should write my N910V IMEI to a Galaxy S4 I545 (Does it have to be Verizon or any S4 phone?) ? Then using that Galaxy S4 to remove the Reactivation Lock? So when i remove the Activation Lock from the S4 would automatically be removed from my N910V? That really makes sense | |
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
01-30-2017, 13:36 | #58 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | am having sm-n910v android version 5.0.1 reactivation lock bypass plz help i have gone through all the steps but couldnt help me any thing , |
01-31-2017, 03:13 | #59 (permalink) | |
1.) Use OTG cable and launch settings (https://www.youtube.com/watch?v=DJ8_qbj1DPQ) 2.) Open Accounts and add Google account 3.) Open Lock Screen and Security 4.) Open Find My Mobile 5.) Click http://findmymobile.samsung.com ( it will open up a browser) 6.) Search Google Play Store and launch it 7.) Google Play Store opens up and then search for KNOX and install it 8.) Launch KNOX and Register 9.) Now search for a launcher like APEX and when it is done click open (should take you to home launcher) 10.) Open up KNOX and MORE and KNOX Settings in the upper right 11.) Click Account 12.) Add SAMSUNG account ( I also added google account but dont think its needed) 13.) I then set KNOX stlye to Launcher and it restarted the UI 14.) On the Samsung Protection screen Log into the samsung account you signed into with in KNOX | |
The Following 9 Users Say Thank You to GalaxyVibe For This Useful Post: |
