08-06-2017, 05:41 | #92 (permalink) |
No Life Poster Join Date: Sep 2009 Location: 9ja
Member: 1110430 Status: Offline Thanks Meter: 104 | Pls i need to flash N910V but cant see on the list, I s it save to select G920V or which model to use in flashing the N910v ? I actually want to remove pattern lock but hardreset not allowed on the phone. Pls what model to select to flash the phone? Thanks in advance. |
08-14-2017, 05:36 | #93 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | as i know i tried all these method and every solution on the web side none of them work,, to remove the reactivation account it must be done by samsung capture tool via GSPN only and not many people have access to samsung account or via GSPN program. IF AIM WRONG PLEASE CORRECT ME THANKX |
08-26-2017, 14:54 | #94 (permalink) | |||
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
09-07-2017, 14:35 | #95 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
I can confirm that some Verizon models appear to have a firmware bug, where you can BYPASS it, but not actually turn off the React Lock in the security menu. You can use the phone normally without being able to enter a samsung account, till you do a full factory reset. Then you must do a bypass over again. The same exact bypass and turn off method works perfectly fine on all gsm models, so it's not worth wasting any more time and effort on this issue. imho Last edited by BillA; 09-07-2017 at 14:41. | |
The Following User Says Thank You to BillA For This Useful Post: |
09-08-2017, 00:45 | #96 (permalink) | |
09-12-2017, 11:46 | #100 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | So i managed to remove reactivation lock from a verizon Note 4 but idk what really removed it but here is a rundown what i did. 1. Flashed combination file 2. ADB installed galaxy apps 3. Signed in my samsung account in galaxy apps 4. Flashed N910VVRU2BOG5 5. Tried signing in to account which did not work so i used OTG method to get to browser 6. Typed in My Knox and clicked on playstore link 7. Signed in to my gmail account 8. Downloaded My Knox, set everything up, then you go to Knox Settings 9. Added my samsung account 10. Went to recovery and did a factory reset 11. Flashed N910VVRU2BPA1 12. It let me sign in with my samsung account and went to settings, security and unchecked reactivation lock 13. Typed in my password and the checkmark remained unchecked. Download mode confirmed it is off |
The Following 5 Users Say Thank You to CloseCOder For This Useful Post: |
10-13-2017, 16:42 | #102 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1391525 Status: Offline Thanks Meter: 47 | finally got solution for N910v 5.0.1 reactivation bypass ... its work for me all credit goes to :-Richard Brown tnx for help ... https://www.youtube.com/watch?v=4LPgiYFEvzw |
10-18-2017, 23:17 | #103 (permalink) |
Junior Member Join Date: Dec 2015 Location: LP, FLORIDA
Member: 2508499 Status: Offline Thanks Meter: 0 | I just bought a z3x box full for samsung and lg. I have samsung tool pro installed and ready... I have a SCH-i545 that has been a major pain. Samsung reactivation locked. Need solution. Thx |
10-28-2017, 04:25 | #104 (permalink) | |
Insane Poster Join Date: Oct 2017
Member: 2770461 Status: Offline Thanks Meter: 24 | Quote:
BUT THIS WORKS! I followed the steps exactly, and it works perfectly. The only difference is that on step 5 it let me use my account. I still passed the setup wizard and installed myknox and added my account. While I was still in myknox, i rebooted into recovery and followed the rest of the steps and this dang thing is unlocked! FINALLY! You are my hero. The sad part of this is that of literally THOUSANDS of posts I researched in the process, yours is the only that works perfectly. And you only had 1 thanks! There were others with dozens that simply did not work. I think that the hard reset from recovery with the account in samsung knox did it. I never thought to hard reset from recovery in all of this process. | |
The Following User Says Thank You to dmonsta86 For This Useful Post: |
