Old 01-24-2017, 00:34   #46 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Originally Posted by CHANDARAKK View Post
lol itr diffrent Qualcom and SPD not the same
Okay, I see. So when I unzip my N910VVZW2BOG5 firmware, I get "aboot.mbn, boot.img, cache.img.ext4, carrier.img.ext4, modem.bin, NON-HLOS.bin, persist.img.ext4, recovery.img, rpm.mbn, sdi.mbn, system.img.ext4, TRLET_USA_VZW.pit, tz.mbn" So which files I need to rebuild to a single Tar file to activate ADB on my phone?
Old 01-26-2017, 21:03   #47 (permalink)
Member: 1067092
Thanks Meter: 2
Hey GalaxyVibe, I had to pay 13 bucks for it (remote by pc)..! I was desperate about my phone issue, many days without use it, you know..!
Samsung account and reactivation lock all gone..! Good luck and if you know finally about any free solution, please put it here for future references, we never know.
At last thanks again for help and effort..!
Old 01-27-2017, 00:54   #48 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Cool
I am sorry to hear that. I will defenetely post a solution when I get it. That is what is this website about. FREE solutions!
Old 01-30-2017, 01:55   #49 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Hello guys, I keep trying to remove the Samsung Reactivation (KK) lock. I installed the Combination files and selected the G920P model:
UNLOCK INSTRUCTIONS:
Domestic Unlock:
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock Domestic' button.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Reset FRP/React/EE
Selected model: SM-G920P
Software version: 27.7
Searching Samsung USB Flash interface... COM3 detected
Setup connection... Ok
Reading PIT from phone... Ok
Searching FRP lock... Ok
Erasing FRP lock... error
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G920P" "Erasing FRP lock error" - Пошук Google
Done with Samsung Tool PRO v.27.7
Old 01-30-2017, 01:56   #50 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
I also tried the G920V model:
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Unlock' button for direct unlock.
4. After phone reboot, go to settings and perform factory reset.
Selected model: SM-G920V
Selected port: COM8 USB Serial Port
Searching Samsung USB Flash interface... COM17 detected
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G920V" "Erasing FRP lock error" - Пошук Google
Old 01-30-2017, 01:56   #51 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Please helppppppppppppppppppppppppppppp!!!
Old 01-30-2017, 02:52   #52 (permalink)
Member: 2444830
Thanks Meter: 162
So I see you got the phone back your hands again...
Sent from my SM-N930T using Tapatalk
Old 01-30-2017, 02:58   #53 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Yes brother. I am really up to finding out how to remove this OLD and sticky lock LOL
Old 01-30-2017, 02:59   #54 (permalink)
Member: 2444830
Thanks Meter: 162
Yeah I understand, I'm all out of ideas maybe someone else could chime in....
The Following User Says Thank You to JT man For This Useful Post:
Old 01-30-2017, 03:09   #55 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Thank you my Brother
Old 01-30-2017, 04:19   #56 (permalink)
Crazy Poster
Member: 2475865
Thanks Meter: 15
You can do it with two different options...
1. Flash combination firmware and add your dummy samsjng account, flash back to stock but it has to be 5.0, at the start process it will let you remove *Reactivation Lock*
2. Clone phone IMEI into a Galaxy S4 and remove it from that end and you will see remove the RL after performing a Hard reset ...
The Following User Says Thank You to iDonTuseRubbers For This Useful Post:
Old 01-30-2017, 05:09   #57 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
1. I flashed the Combination files but the when I am at the Combination firmware, I click on the "Accounts" option in settings but nothing happens. I already have my Samsung Account on the phone. When i flash the 5.0.1 firmware, the phone does not give me the option of removing the Reactivation lock. I get to enter my Samsung Account and password but nothing else. Please correct me if there is anything wrong there.
2. This I have not tried it yet. Do you mean that i should write my N910V IMEI to a Galaxy S4 I545 (Does it have to be Verizon or any S4 phone?) ? Then using that Galaxy S4 to remove the Reactivation Lock? So when i remove the Activation Lock from the S4 would automatically be removed from my N910V? That really makes sense
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Old 01-30-2017, 13:36   #58 (permalink)
Member: 2528503
Sonork: 1670792
Thanks Meter: 70
am having sm-n910v android version 5.0.1 reactivation lock bypass plz help
i have gone through all the steps but couldnt help me any thing ,
Old 01-31-2017, 03:13   #59 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Step by step Samsung Account Reactivation Bypass intructions (By bigshotrob22 at XDA Developers)
1.) Use OTG cable and launch settings (https://www.youtube.com/watch?v=DJ8_qbj1DPQ)
2.) Open Accounts and add Google account
3.) Open Lock Screen and Security
4.) Open Find My Mobile
5.) Click http://findmymobile.samsung.com ( it will open up a browser)
6.) Search Google Play Store and launch it
7.) Google Play Store opens up and then search for KNOX and install it
8.) Launch KNOX and Register
9.) Now search for a launcher like APEX and when it is done click open (should take you to home launcher)
10.) Open up KNOX and MORE and KNOX Settings in the upper right
11.) Click Account
12.) Add SAMSUNG account ( I also added google account but dont think its needed)
13.) I then set KNOX stlye to Launcher and it restarted the UI
14.) On the Samsung Protection screen Log into the samsung account you signed into with in KNOX
The Following 9 Users Say Thank You to GalaxyVibe For This Useful Post:
Old 02-11-2017, 16:27   #60 (permalink)
Member: 2210849
Thanks Meter: 12
No solutions for the N910V yet?
The Following User Says Thank You to igo4pro For This Useful Post:
Page generated in 0.28182 seconds with 8 queries
