Old 02-11-2017, 16:08   #61 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
Originally Posted by igo4pro View Post
No solutions for the N910V yet?
iDonTuseRubbers says: "Clone phone IMEI into a Galaxy S4 and remove it from that end and you will see remove the RL after performing a Hard reset ... "
This I have not tried it yet. I should write my N910V IMEI to a Galaxy S4 I545, then using that Galaxy S4 to remove the Reactivation Lock. So when i remove the Activation Lock from the S4 would automatically be removed from my N910V. That really makes sense. Please let me know if anybody has tried this solution and it is successfull on the N910V. Thanks.
Old 02-11-2017, 16:39   #62 (permalink)
Member: 2210849
Thanks Meter: 11
i will give a try. i have many s4 to do so, well iw ill give my response as soon as i test it.
The Following User Says Thank You to igo4pro For This Useful Post:
Old 02-11-2017, 17:41   #63 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
Thank you!! Please report back
Old 02-11-2017, 18:39   #64 (permalink)
Member: 2210849
Thanks Meter: 11
didnt worked for me on I545 S4.
Old 02-11-2017, 20:22   #65 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
So what did you do?
So you bypassed the N910V to home screen. Then you cloned your N910V IMEI to your I545 S4 phone. You added your same Samsung Account that you used to bypass your N910V. There in your S4, you removed the "Reactivation Lock". With your s4 still signed in, you should hard reset your N910V and the Reactivation lock should have been gone.
Old 02-11-2017, 21:05   #66 (permalink)
appsworlmardan's Avatar
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 141
Try with realtrum your problem solved
Old 02-11-2017, 21:19   #67 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
Thank you brother. My problem is not to bypass the Samsung lock. My problem is to turn off the reactivation lock on the phone to make it stop asking for a Samsung account.
Old 02-14-2017, 17:25   #68 (permalink)
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 141
Thumbs up Using of realterm
You can easily sing in another Samsung account
Step by step done all the procedure
When your phone is calling mode
Save immediately number
When you save the contact
At the last you can see sent bussines card
Automatically you are enter on Samsung store
Put another id of Samsung account
Then sing in
Restart the phone
Your new I'd is enter
I also done with this procedure
Then go to apps disible Samsung account
Old 02-14-2017, 19:25   #69 (permalink)
Member: 2277857
Thanks Meter: 55
Then sing in
Restart the phone
The issue is not getting another Samsung account in the phone, the problem with several Verizon phones is that you cannot uncheck the Reactivation Lock flag and remove it completely. The same issue on the SM-G900V, and maybe others. Your method works on other carriers but Verizon it does not.
The Following User Says Thank You to brg7562 For This Useful Post:
Old 02-14-2017, 20:52   #70 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
Nobidy could have said it better than you my brother
Old 02-15-2017, 22:57   #71 (permalink)
Member: 2210849
Thanks Meter: 11
I've found a way to use our Verizon N910V almost complete. Follow this steps tested by me on
6.0.1 N910VVRS2CQA1_N910VVZW2CQA1_VZW firmware.
1-Turn off the phone.
2-Turn it on then Enter Download Mode (Vol-/Home/Power) then Vol up.
3-Press Vol Down and Power Button and keep pressing them till you see the Maintenance Boot Menu.
4-Scroll down using Vol- Choose the option #5 USB Debug with Home Button.
5-Phone will launch debugging option pop-up when connected to the pc, use WinDroid Toolkit v3.1 or
something similiar to install MobileGo.apk, then install QuickShortcut Maker.apk and restart the phone.
6-Once in the Set Up screen put your finger on lower right corner and slide it to the middle of the screen
to trigger the MobileGo app and Scroll the wheel to find a + sign to add installed apps from the phone.
7-Choose Quickshorcutmaker to the quick launch app to pin it on MobileGo. Open Quickshorcutmaker
and write "Home" to find Home Launcher to go to the phone home screen.
8-Enjoy!
Sorry for my bad english!
The Following 2 Users Say Thank You to igo4pro For This Useful Post:
Old 02-16-2017, 00:02   #72 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
8-Enjoy!
Wow, thank for the tutorial. Actually the problem is not to bypass the Samsung lock, the problem is to turn off the Samsung Reactivation lock
Old 02-16-2017, 01:08   #73 (permalink)
Member: 2210849
Thanks Meter: 11
Yes, i know this is a big problem. But i'm sure knox is the key to do the trick to remove the Reactivation Lock. i need some time to find it on this model.
Old 02-16-2017, 01:15   #74 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
Great! Please do not forget to post the solution when you find it out.
Old 02-28-2017, 01:15   #75 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 688
I also try writing the same IMEI of the N910V into a Galaxy S6 Edge to try to remove the Reactivation Lock but the method did not work for me.
Page generated in 0.52037 seconds with 7 queries
