10-28-2017, 18:08 | #106 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
1. download and flash a combination 2. download galaxy apps apk and install it via adb 3. connect to wifi on combination, make sure date and time is set to automatic. 4. click on the newly installed galaxy apps icon and sign into a pre existing samsung account. 5. put the phone in download mode and flash back stock. 6. extract the modem from the combination file you just flashed. once your phone is at welcome screen, put the phone back in download mode and flash the MODEM you extracted from the combination. 7. once it flashes and its back and welcome screen, connect to wifi and go through setup. 8. then it will ask for samsung account. sign into the one you used on the combination. 9. once your at home screen go to settings and do a factory reset. 10. now flash back stock MODEM and go through setup wizard and it will not ask for samsung account. | |
The Following 7 Users Say Thank You to Mr_F10ch3 For This Useful Post: |
10-28-2017, 22:09 | #107 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | Quote:
10-30-2017, 15:29 | #108 (permalink) | |
11-30-2017, 16:34 | #112 (permalink) | |
Freak Poster Join Date: May 2013 Location: Haiti
Member: 1940476 Status: Offline Thanks Meter: 27 | Quote:
01-17-2018, 22:44 | #115 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | just flash entire combo file. install samsung apk via adb command then add samsung account and then flash stock rom back and when it asks for samsung info just put in info you used while combo file was on phone. make sure when you flash stock rom back to flash a 5.1.1 rom or lower. if you flash 6.0.1 rom it will says processing error when you try to log into samsung account |
06-01-2018, 03:33 | #118 (permalink) | |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
09-11-2018, 19:49 | #120 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678967 Status: Offline Thanks Meter: 3 | problems i flash combination to get out the reactivation lock on the n910v verizon note . The combination worked now trying to flash back the android 6 firmware odin is giving me errors on flashing. Anybody knows i feel i bricked the phone |
