07-06-2013, 17:44 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Galaxy S3 i747, T999 version 4.1.2 FAILED TO UNLOCK i tried until now with 7 units a i tried until now with 7 units and for all must downgrade to 4.1.1 is any solution not to downgrade? Selected model: I747M Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443072 Reading security... error access denied Done with Samsung Tool v.15.0 Done with Samsung Tool v.15.0 |
07-08-2013, 23:57 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Same problem Different version of Galaxy S III (Koodo Canada) Selected model: I747M Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443072 Reading security... error access denied Done with Samsung Tool v.15.0 |
07-09-2013, 00:03 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Please post here version of phone firmware T999 with problem like this. We will test on our phone. Last edited by blang; 07-09-2013 at 00:29. |
07-10-2013, 13:40 | #6 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Selected model: I747M Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443072 Reading security... error access denied Done with Samsung Tool v.15.0 Done with Samsung Tool v.15.0 baseband i747mvldmf1 but it happened with ALL 4.1.2 version doesn't matter the baseband version |
07-10-2013, 18:36 | #8 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | when you dail *#7284# What option you can see ? when you dail *#9090# What option you can see ? when you dail *#0808# What option you can see ? |
The Following 2 Users Say Thank You to blang For This Useful Post: |
07-12-2013, 23:02 | #11 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1693317 Status: Offline Thanks Meter: 2 | friend, what was the solution on this? i have the same problem Selected model: I747M Reading security... error access denied, it reads the phone, imei, buld, but reading info, i tried with version 12.1 also with usb data with PC, unable DEBUG phone, and the same problem Reading security... error access denied, the phone has 4.2.1 version i747M model, and it is already root |
07-13-2013, 00:51 | #12 (permalink) | |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Quote:
no solution until now. Blanq work on this Short solution is downgrade the phone to 4.1.1, worked 100% | |
07-13-2013, 22:42 | #13 (permalink) |
Member: 1693317 Status: Offline Thanks Meter: 2 | i donwgrade to 4.1.1 i already get the codes, also unlock direct DONE, but i put other sim card ans still LOCKED, why? it is I747M TELCEL, help me please Selected model: T989 Selected port: COM13 Z3X Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.14.8 Selected model: T989 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443028 Done with Samsung Tool v.14.8 Selected model: T989 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443028 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.8 Selected model: T989 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443028 Reading security... OK Searching server... OK NET lock: #7465625*638*63820713# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.8 |
07-14-2013, 16:14 | #14 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
try restart phone and enter again. | |
07-15-2013, 19:42 | #15 (permalink) |
Insane Poster Join Date: May 2009 Location: unknown planet
Member: 1033535 Status: Offline Thanks Meter: 24 | Hello i have the same problem try to unlock Samsung galaxy s3 i get this error Reading security... error access denied what is this I've tried all this instruction this *#9090# doesn't work for this I747M model only *#7284# any help ? i use Z3X box |
