12-11-2013, 07:24 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1565387 Status: Offline Thanks Meter: 6 | Galaxy S3 Mini SM-G730W8 Unlock DONE but... Only Emergency calls I try unlocking the galaxy s3 mini SM-G730W8 with Z3X using as the G730A Product ... Unlock is Done, detect sim card but signal fall in only Emergency Calls seconds ago... As I can solve? Thank you for your assistance and help and Sorry for my bad english Enviado desde mi HTC One X usando Tapatalk 2 |
The Following User Says Thank You to cesargmoy For This Useful Post: |
12-11-2013, 18:39 | #2 (permalink) |
Member: 1565387 Status: Offline Thanks Meter: 6 | Hi... Today the signal is normalized, maybe the problem was operator,and is working perfect... Unlock Done Selected model: G730A Selected port: COM108 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G730W8 Android version: 4.2.2 Product code: SM-G730WMBATLS Phone version: G730W8VLUAMI2 PDA version: G730W8VLUAMI2 CSC version: G730W8OYAAMI2 IMXX: 3577XXXXXXXXXX Phone S/N: R31XXXXXXX Checking phone at COM108 OK Backuping NVM... OK Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM108 OK Restoring NVM... OK Reseting... OK Unlock done Done with Samsung Tool v.16.3 |
12-27-2013, 16:08 | #4 (permalink) |
Insane Poster Join Date: Dec 2012
Member: 1847451 Status: Offline Thanks Meter: 45 | use cydia impactor to root https://cydia.saurik.com/api/latest/2 |
The Following User Says Thank You to harpreetbraich For This Useful Post: |
12-28-2013, 16:23 | #6 (permalink) | |
Member: 1565387 Status: Offline Thanks Meter: 6 | Quote:
Please first Check in last Z3X Samsung Tool If relase SM-G730W8 support... If is'nt: *Unlock 1. In keyboard phone call: *#0808#, select DM+MODEM+ADB and save 2. Restart 3. Select model G730A 4. Select the Samsung diagnostic port detected in Port 6. Press Unlock 7. The process in a moment says "the Selected model isnt correct and maybe damage cellphone... Im run the risk and done ejejej... Do this Under your responzability jeje 5. Ready Enviado desde mi HTC One X usando Tapatalk 2 | |
12-30-2013, 23:27 | #7 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Hello Try solved the root, use this soft VRoot_1.7.0.3882_Setup put the mobile in debug mode in less than two minutes phone root, after direct unlock and go. |
12-31-2013, 06:06 | #9 (permalink) | |
No Life Poster Join Date: Jan 2009
Member: 955311 Status: Offline Thanks Meter: 241 | Quote:
The Following User Says Thank You to maazi For This Useful Post: |
