06-16-2015, 18:42 | #1 (permalink) |
Freak Poster Join Date: Sep 2013 Location: PR
Member: 2032498 Status: Offline Thanks Meter: 39 | Galaxy s6 edge g925t not up help!!! |
06-16-2015, 19:07 | #5 (permalink) |
Member: 2032498 Status: Offline Thanks Meter: 39 | if I have the original copy EFS the problem is that not up the system and Odin says pass what I try is to restore EFS using a tar by Odin funny thing is that I get the IMEI barcodes but still not up then repeatedly flash |
The Following User Says Thank You to APUAK47 For This Useful Post: |
06-16-2015, 19:10 | #6 (permalink) | |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Quote:
Sent from my SM-G925T using Tapatalk | |
06-16-2015, 20:04 | #7 (permalink) |
Member: 2032498 Status: Offline Thanks Meter: 39 | exactly the same seemed to have a softbrick but I made a flash with Odin and the message was but now left in the galaxy samung logo s6 edge and there is nothing but excuse my bad English jeje |
06-16-2015, 20:46 | #9 (permalink) |
Member: 2032498 Status: Offline Thanks Meter: 39 | le di un reset a al carpeta efs luego cuando dio el reboot entro en un softbrick le di un flash con odin a la 5.1.1 y salio de hay pero sigue quedandoce en el logo te deja entrar al recovery y darle un hard reset pero aun asi sigue atascado en el logo |
06-16-2015, 20:48 | #10 (permalink) |
Member: 2032498 Status: Offline Thanks Meter: 39 | pence que hiso el reset a la efs pero cuando entras al recovery puedes ver los codigos d de barra del imei y el serial osea no los perdio pero aun asi no sube no se pq razon |
