Old 05-16-2018, 18:15   #16 (permalink)
Member: 63646
Sonork: 1670920:45069
Thanks Meter: 20
Thanks this is 100% working solution . I have S6 G920F 7.0 with reactivation lock on. I flashed s-boot from this combination file. After that phone hangs on startup, no problem, switch phone off en put in download mode again.
After this use z3x 25.5 en select model g920F, unlock , reset frp/ee.
It gives erasing ok . phone hangs on startup, no problem. Switch off en put in download mode again, flash stock rom 7.0 and voila phone is working again en samsung accoount/reactivation lock is OFF . thanks
The Following 4 Users Say Thank You to 45069 For This Useful Post:
Old 08-22-2018, 17:21   #17 (permalink)
Member: 2456497
Thanks Meter: 4
U6 frp
For U6, flash combination, go again to download mode, select G531F as a model and unlock FRP
Then install normal firmware again as G920. You will see when going to flash normal firmware REACTIVATION LOCK: OFF
(if you get an error when flashing firmware, deselect hiddenimg and reflash)
The Following 4 Users Say Thank You to drageloth For This Useful Post:
Page generated in 0.17520 seconds with 7 queries
