Old 02-01-2018, 15:24   #1 (permalink)
-Mosin-'s Avatar
Member: 1948608
Thanks Meter: 1,414
Thumbs up galaxy S6 SM-G920F imei 350000,DRK,EFS,NV repair Done
sm-g920f imei,drk repair done z3x
Operation: Repair DRK
Selected model: SM-G920F
Software version: 30.5
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM4 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... OK
Reading phone info...
Recovery build version: 6.0.1
Boot version: G920FXXU5DQAJ
Platform: exynos7420
Boot serial: 02157df2ad17ec1d
Product board: zeroflte
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Checking DRK status... NG!
Writing DRK... OK
Repairing DMVT key... OK
Rebooting phone... OK
Repair DRK done
Done with Samsung Tool PRO v.30.5
Operation: Write CERT
Model: SM-G920F
Android version: 6.0.1
Product code:
Phone version: G920FXXU5DQA2
PDA version: G920FXXU5DQAJ
CSC version: G920FXFV5DQA1
CSC country code: South Africa
CSC sales code: XFV
HW version:
Phone SN: 00000000000
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-02-01
RF cal date:
IMEI: 350000000000006
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Running zTool, please wait... OK
HWID: 08 83 8B EE 76 07 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Initialization AT RIL...
AT RIL stopped, restarting... OK
Checking for compatible phone and cert
Phone KEY ID: 0346
Checking certificate file... OK
KEY ID: 0346
Crypting CERT 1... OK
Writing NV data... OK
Write CERT done
The Following 4 Users Say Thank You to -Mosin- For This Useful Post:
Old 02-27-2018, 21:10   #2 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
can you share files ?
Old 02-27-2018, 21:46   #3 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
can you share ,DRK,EFS,NV files pls.
Old 02-28-2018, 12:39   #4 (permalink)
-Mosin-'s Avatar
Member: 1948608
Thanks Meter: 1,414
download link
https://www.4shared.com/zip/CVf1RjZL...0F_efs_NV.html
The Following 3 Users Say Thank You to -Mosin- For This Useful Post:
Old 02-28-2018, 14:04   #5 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Write CERT' to restore certificates.
7. Press 'Write NV DATA' if you need to restore NV backup.
Read certificate operation:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read CERT' button to read certificates.
Read certificate via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read CERT DIAG' button to read certificates.
Software version: 30.8
Model: SM-G920F
Product code:
Phone version:
PDA version: G920FXXU5DQA7
CSC version: G920FDBT5DQA3
CSC country code: Germany
CSC sales code: DBT
HW version:
Modem board:
Security patch: 2017-01-01
RF cal date:
IMEI:
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... error (0 6)
Start... OK
Reading data from phone... error (0)
Try downgrade modem if possible
Done with Samsung Tool PRO v.30.8
I have not cer file
and always this message
Old 02-28-2018, 15:02   #6 (permalink)
Crazy Poster
Member: 2704296
Sonork: 100.1677478
Thanks Meter: 4
can you share Root file please
Old 02-28-2018, 15:07   #7 (permalink)
-Mosin-'s Avatar
Member: 1948608
Thanks Meter: 1,414
root marshmallow [copy nd paste down link in address bar]
download.chainfire.eu/733/CF-Root1/CF-Auto-Root-zeroflte-zerofltexx-smg920f.zip?retrieve_file=1
The Following 2 Users Say Thank You to -Mosin- For This Useful Post:
Old 02-28-2018, 15:53   #8 (permalink)
Member: 478535
Thanks Meter: 278
Model: SM-G920F
Product code:
Phone version:
CSC sales code: DBT
HW version:
Modem board:
RF cal date:
IMEI:
Reading data... OK
Reading MODEM... OK
Start... OK
I have not cer file
Repair modem first but don't upgrade phone firmware until all operations complete, that is, get version 6.0.1 with same binary:
After, read phone to check if modem is ok like:
Phone version: G920FXXU5DPL3
Then do all the efs, nv, cert operations!
Also, your problem may be related to the damaged modem! after you repair modem you probably recover original imei! verify that!
DRK is an operation you do to repair a certain condition of phone, not a file to be shared!
If your phone does an error on recovery mode with the info:
dm-verity verification failed need to check DRK
Then you need to do the DRK repair using UART cable with box!
Old 02-28-2018, 16:08   #9 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
How to repair modem . can you explain pls .
Old 02-28-2018, 16:24   #10 (permalink)
Member: 478535
Thanks Meter: 278
From your log, the firmware installed in your phone is from germany dbt so, you do a search for G920FXXU5DQA7 on s.ammobile and you'll see many firmware from various regions. Just get the Germany DBT one:
https://www.sXammobile.com/firmwares...U5DQA7/122610/ (remove X from sam)
Flash it to see if you get modem repaired! You can flash only the modem, instead of all the fw so you save 1 minute or 2.
Old 02-28-2018, 18:05   #11 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
how to use
I have box just arived yesterday
can you explain please
Old 02-28-2018, 18:22   #12 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 32
I have z3x box
how to use
DRK repair using UART ??
Page generated in 0.42771 seconds with 7 queries
