03-29-2017, 01:31 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2695168 Status: Offline Thanks Meter: 7 | Galaxy S7 Edge G935F Custom Binary (RECOVERY) Blocked By FRP Lock Can't get into Recovery, when I try to reboot I get "Use the Emergency recovery function in the Smart Switch PC software" which doesn't work as well. It seems that EVERYTHING is a Custom Binary and I can't flash anything at all. I was able to get to Recovery once and there was a red "dm-verity failed" line. Reset FRP/React/EE option doesn't work - also blocked by FRP. Is there anything I could try? |
03-29-2017, 01:51 | #2 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | Quote:
Flash stock lower firmware then retry frp! Sent from my iPhone using Tapatalk | |
03-29-2017, 02:48 | #3 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
03-29-2017, 11:53 | #5 (permalink) |
Junior Member Join Date: Dec 2007
Member: 666208 Status: Offline Thanks Meter: 2 | blocked by FRP lock usually because flashing not correct sboot file/or wrong firmware. if u can found phone's Serial number. u can use smartswitch to find correct regional firmware |
03-29-2017, 13:44 | #6 (permalink) | |
Member: 2695168 Status: Offline Thanks Meter: 7 | Quote:
I was able to flash modem though so I'll try repairing DRK now, maybe that will help. Smart Switch gave me correct regional firmware - I'm trying to flash the exact firmware Smart Switch was going to. Thanks. | |
03-30-2017, 00:07 | #8 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | Try and full flash a 6.0.1 firmware to the phone first using odin, Like the 4 part firmware, BL AP CP and CSC. Then erase FRP. Post update br -blu |
03-30-2017, 19:01 | #10 (permalink) |
Member: 168090 Status: Offline Thanks Meter: 92 | @watevah That would be strange, I have not yet come into your problem, it should install Stock firmware via odin through download mode even if the FAP lock is on. I know you cannot install any custom firmware or it's sort if FAP lock is on but stock firmware it always should. Perhaps other users here might come to the rescue regarding your issue. br -blu |
03-30-2017, 19:08 | #11 (permalink) |
Crazy Poster Join Date: May 2016
Member: 2569608 Status: Offline Thanks Meter: 63 | all you should have to do is flash 7.0 then use this bypass http://forum.gsmhosting.com/vbb/f453...7-0-a-2209835/ |
03-30-2017, 20:56 | #12 (permalink) |
Member: 2695168 Status: Offline Thanks Meter: 7 | Yeah, I never had any issues flashing whatever version stock on FRP locked phones but this one is a special case. |
The Following User Says Thank You to watevah For This Useful Post: |
03-30-2017, 22:06 | #13 (permalink) |
Member: 2569608 Status: Offline Thanks Meter: 63 | did you try to flash 7.0 ? im sure it will work when it does that method to bypass frp will work to get it off. if 7.0 dont flash pm me ill give you my whatsapp we will get it done |
03-31-2017, 12:55 | #14 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Paris,Serbia Age: 34
Member: 957371 Status: Offline Sonork: Non user Thanks Meter: 189 | Quote:
One user gived me this solution and ist WORKK IM HAPPY NOW Dear user! In order to flash your phone as the Allunlockingsource user, you first have to solve the FRP This happens because of a security issue that you can not do flash by having the reset block performed If you have some of these firmwares on your phone, you can solve the FRP with chimera. 6.0.1 SM-G935F G935FXXU1APB3 04/02/2016 6.0.1 SM-G935F G935FXXU1APAW 01/29/2016 If you do not know what firmware you have, put your phone in recovery mode and in the second line you will see your sw. Chimera writes eng boot of G935FXXU1A ... Therefore, it stuck On logo. You can flash with G935FXXU1A ... Factory reset phone And then use New FRP method of Chimera. It should power on with ADB enabled. You are recomanded to make an attempt to flash your phone with this 4-file firmware with Odin 3.12.3 https://firmware.gem-flash.com/index...e-info&id=7937 THANKS TO : gcceleghg | |
03-31-2017, 12:58 | #15 (permalink) |
Member: 957371 Status: Offline Sonork: Non user Thanks Meter: 189 | Download last odin and firmware from this site and look at the magic <ID:0/005> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/005> Odin engine v(ID:3.1203).. <ID:0/005> File analysis.. <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Set PIT file.. <ID:0/005> DO NOT TURN OFF TARGET!! <ID:0/005> Get PIT for mapping.. <ID:0/005> Firmware update start.. <ID:0/005> SingleDownload. <ID:0/005> sboot.bin <ID:0/005> param.bin <ID:0/005> cm.bin <ID:0/005> boot.img <ID:0/005> recovery.img <ID:0/005> system.img <ID:0/005> modem.bin <ID:0/005> Transmission Complete.. <ID:0/005> Now Writing.. Please wait about 2 minutes <ID:0/005> Receive Response from boot-loader <ID:0/005> cache.img <ID:0/005> hidden.img <ID:0/005> RQT_CLOSE !! <ID:0/005> RES OK !! <ID:0/005> Removed!! <ID:0/005> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
The Following User Says Thank You to stevandnk@gma For This Useful Post: |
