02-27-2016, 16:25 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | GT-I9190 UPGRADE Hidden.img error Code: Galaxy S4 Mini GT-I9190 SEK I9190XXUBNB2 Android 4.2.2 07.02.2014 2451427 Galaxy S4 Mini GT-I9190 SER I9190XXUCOC1 Android 4.4.2 27.03.2015 4573031 Galaxy S4 Mini GT-I9190 TUR I9190XXUCOD2 Android 4.4.2 21.04.2015 4746842 |
02-27-2016, 16:35 | #3 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: United Kingdome
Member: 1507640 Status: Offline Thanks Meter: 131 | hi Quote:
flash with below file it will be fine https://download.chainfire.eu/423/CF...ub-gti9190.zip | |
The Following User Says Thank You to mobileboothuk For This Useful Post: |
02-27-2016, 17:11 | #5 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | 1. rom not needed old i dont want downgrade (hidden.img error) 2. rom succesful flash (no error) 3. rom (z3x timeout error odin FAIL! (Size)) Code: [ 27.02.2016 17:18:00 ] Operation: Flash [ 27.02.2016 17:18:00 ] Selected model: GT-I9190 [ 27.02.2016 17:18:00 ] Software version: 24.4 [ 27.02.2016 17:18:00 ] [ 27.02.2016 17:19:00 ] File analysis... OK [ 27.02.2016 17:19:00 ] Total file size: 0x5DA19F4C (1498 Mb) [ 27.02.2016 17:19:00 ] Searching USB Flash Interface... detected COM10 [ 27.02.2016 17:19:00 ] Setup connection... OK [ 27.02.2016 17:19:00 ] Reading PIT from phone... OK [ 27.02.2016 17:19:00 ] Sending boot.img... OK [ 27.02.2016 17:19:00 ] Sending recovery.img... OK [ 27.02.2016 17:19:00 ] Sending system.img.ext4... OK [ 27.02.2016 17:24:00 ] Sending cache.img.ext4... OK [ 27.02.2016 17:25:00 ] Sending hidden.img.ext4... OK [ 27.02.2016 17:25:00 ] Sending NON-HLOS.bin... OK [ 27.02.2016 17:25:00 ] Sending aboot.mbn... OK [ 27.02.2016 17:25:00 ] Sending sbl2.mbn... OK [ 27.02.2016 17:25:00 ] Sending sbl3.mbn... OK [ 27.02.2016 17:25:00 ] Sending rpm.mbn... OK [ 27.02.2016 17:25:00 ] Sending tz.mbn... OK [ 27.02.2016 17:25:00 ] Flashing done (time - 00:06:21) [ 27.02.2016 17:25:00 ] [ 27.02.2016 17:34:00 ] Operation: Flash [ 27.02.2016 17:34:00 ] Selected model: GT-I9190 [ 27.02.2016 17:34:00 ] Software version: 24.4 [ 27.02.2016 17:34:00 ] [ 27.02.2016 17:34:00 ] File analysis... OK [ 27.02.2016 17:34:00 ] Total file size: 0x64331168 (1603 Mb) [ 27.02.2016 17:34:00 ] Searching USB Flash Interface... detected COM10 [ 27.02.2016 17:34:00 ] Setup connection... OK [ 27.02.2016 17:34:00 ] Reading PIT from phone... OK [ 27.02.2016 17:34:00 ] Sending aboot.mbn... OK [ 27.02.2016 17:34:00 ] Sending sbl2.mbn... OK [ 27.02.2016 17:34:00 ] Sending sbl3.mbn... OK [ 27.02.2016 17:34:00 ] Sending rpm.mbn... OK [ 27.02.2016 17:34:00 ] Sending tz.mbn... OK [ 27.02.2016 17:34:00 ] Sending boot.img... OK [ 27.02.2016 17:35:00 ] Sending recovery.img... OK [ 27.02.2016 17:35:00 ] Sending system.img.ext4... OK [ 27.02.2016 17:40:00 ] Sending NON-HLOS.bin... OK [ 27.02.2016 17:41:00 ] Sending cache.img.ext4... OK [ 27.02.2016 17:41:00 ] Sending hidden.img.ext4... error timeout [ 27.02.2016 17:41:00 ] Code: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9190XXUCOD2_I9190OJVCOD2_I9190XXUCOD2_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/010> Added!! <ID:0/010> Odin v.3 engine (ID:10).. <ID:0/010> File analysis.. <ID:0/010> SetupConnection.. <ID:0/010> Initialzation.. <ID:0/010> Get PIT for mapping.. <ID:0/010> Firmware update start.. <ID:0/010> aboot.mbn <ID:0/010> NAND Write Start!! <ID:0/010> sbl2.mbn <ID:0/010> sbl3.mbn <ID:0/010> rpm.mbn <ID:0/010> tz.mbn <ID:0/010> boot.img <ID:0/010> recovery.img <ID:0/010> system.img.ext4 <ID:0/010> NON-HLOS.bin <ID:0/010> cache.img.ext4 <ID:0/010> hidden.img.ext4 <ID:0/010> FAIL! (Size) <OSM> All threads completed. (succeed 0 / failed 1) AFTER flash, flash CFROOT? |
02-27-2016, 17:15 | #6 (permalink) | |
Member: 1918391 Status: Offline Thanks Meter: 73 | Quote: *#1234# ap ok cp ok csn none but reslove this error without root solution. Last edited by gencom; 02-27-2016 at 17:23. | |
02-27-2016, 20:14 | #7 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | I find new solution for odin fail size after hidden.img. flash pit file only.. %1000000000 not for hidden.img error be careful for flashing pit file. flash only correct tested pit |
