12-22-2016, 07:47 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 38
Member: 79786 Status: Offline Thanks Meter: 123 | Gt-i9195 imei repair error Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Code: Operation: Reset MSL Selected model: GT-I9195 Selected port: COM20 SAMSUNG Mobile USB Serial Port Software version: 27.5 Reading phone info... Reading IMEI... Ok IMEI: 0 Reseting MSL security... Ok Reseting... Ok Reset MSL done Done with Samsung Tool PRO v.27.5 Initialization AT RIL... error I can't able to copy the logs, everything is INACTIVE in the Samsung Tool Pro window. Any suggestions from Supporters ? Users ? |
12-22-2016, 17:48 | #4 (permalink) |
Member: 79786 Status: Offline Thanks Meter: 123 | Success Finally After flashing with latest Firmware available, i can able to repair. but i can't find whats wrong with the firmware which was already in the phone. Code: Operation: Repair Selected model: GT-I9195 Selected port: COM20 SAMSUNG Mobile USB Serial Port Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: GT-I9195 Android version: 4.4.2 Product code: Not Active Phone version: I9195XXUCNH5 PDA version: I9195XXUCNH5 CSC version: I9195OJVCNH1 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: R38F10WDE8B Modem board: MSM8930AB RF cal date: NONE IMEI: Initialization AT RIL... Ok Ok Repairing IMEI... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.27.5 |
