10-03-2015, 08:22 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | "adb not selected" field is empty at the ADB tab,u should enable usb debugging first in the phone,let drivers install,then at ADB tab select yr device,click unlock GL PS. u may need to root phone also |
10-03-2015, 08:31 | #3 (permalink) |
Freak Poster Join Date: Jun 2015 Age: 33
Member: 2418095 Status: Offline Thanks Meter: 125 | 1 Clean up the ADB occupied the port, 2 Delete the samsung driver to install In our country, many people encounter this problem. This is our solution I'm sure you've opened the USB debug your driver should also is normal As you see, I also exists the problem before. Adb is not selected |
The Following User Says Thank You to TaiChi gossip For This Useful Post: |
