02-12-2011, 00:46 | #31 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | IMEI: 3551XXXXXXXXX/2 Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM59) Model: GT-P1000N CountryCode: ÄÝ·Òºñ¾Æ/COB Factory SW: UBJJ4 UniqueNumber: 74160002226496 MemoryPhone: KB100D00YM(P1000) Phone SW: P1000XXJK5 Phone S/N: R3XZC44362B IMEI: 35514XXXXXXXX/2 Bypass MSL... OK Reading Security... OK Calculating codes... OK (time - 00:00:00) Freeze code: 00000000 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 STEPS: STEP1. download the patch file ( DO NOT UNZIP!!) STEP2. put phone in download mode (power + vol down + home button) STEP3. choose the patch file in in box that says "phone" STEP4. press update firmware STEP5. press unlock STEP6. put non accepted sim card it will ask for code. enter code. PHONE IS NOW UNLOCKED ! GOOOOOOOD |
02-12-2011, 13:26 | #32 (permalink) |
Junior Member Join Date: Jun 2007 Location: mindoro, philippines
Member: 523516 Status: Offline Thanks Meter: 39 | 2 thumbs up! P1000 (Galaxy tab) Locked in SMART network in the philippines. Count supported models - 223 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM14 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending modem.bin... OK Done with Samsung 3G tool ver 9.4 No answer from phone Done with Samsung 3G tool ver 9.4 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM14 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending modem.bin... OK Done with Samsung 3G tool ver 9.4 Searching Android modem... not found Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM15) Model: GT-P1000 CountryCode: µ¿³²¾Æ Factory SW: P1000DXJK2_OLBJJ2 UniqueNumber: 74200002290201 MemoryPhone: KB100D00YM(P1000) Phone SW: P1000XXJK5 Phone S/N: R22B152870V IMEI: 35296104888056/8 Bypass MSL... OK Reading Security... OK Calculating codes... OK (time - 00:00:00) Freeze code: 00000000 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
02-17-2011, 06:28 | #33 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Cebu Phils.
Member: 183390 Status: Offline Thanks Meter: 74 | here is mine too P1000 T-Mobile Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM17) Model: SGH-T849 SW: T849UVJJB IMEI: 35518204008905/1 Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM17) Model: SGH-T849 CountryCode: ¹Ì±¹/TMB Factory SW: UVJJB UniqueNumber: 75930000257669 MemoryPhone: KB100D00YM(T849) Phone SW: T849UVJJB Phone S/N: R3VZA33421K IMEI: 35518204008905/1 Bypass MSL... error (flash patched firmware first) Done with Samsung 3G tool ver 9.4 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Enable to open COM17 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Enable to open COM17 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Enable to open COM17 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... Done with Samsung 3G tool ver 9.4 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM18 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending modem.bin... OK Done with Samsung 3G tool ver 9.4 Searching Android modem... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM17) Model: SGH-T849 SW: P1000XXJK5 IMEI: 35518204008905/1 Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM17) Model: SGH-T849 CountryCode: ¹Ì±¹/TMB Factory SW: UVJJB UniqueNumber: 75930000257669 MemoryPhone: KB100D00YM(T849) Phone SW: P1000XXJK5 Phone S/N: R3VZA33421K IMEI: 35518204008905/1 Bypass MSL... OK Reading Security... OK Calculating codes... OK (time - 00:00:00) Freeze code: 00000000 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
The Following User Says Thank You to Qmad3 For This Useful Post: |
03-01-2011, 06:50 | #35 (permalink) |
No Life Poster Join Date: Aug 2007 Location: inside the pcb board
Member: 568876 Status: Offline Thanks Meter: 99 | sc-01c unlock????????? i have galaxy tab from japan... it,s like p1000, sc-01c model... here's the logs it is supported by z3x for unlock.... Enable to open COM57 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM91) Model: SC-01C SW: SC01COMJK2 IMEI: 35466304067650/1 Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM91) Model: SGH-N023 CountryCode: ہد؛» Factory SW: SC01COMJK2 UniqueNumber: 74060002332351 MemoryPhone: KB100D00YM(N023) Phone SW: SC01COMJK2 Phone S/N: R4VZB37052E IMEI: 35466304067650/1 Bypass MSL... error (flash patched firmware first) Done with Samsung 3G tool ver 9.4 |
The Following User Says Thank You to :::..CyBoRg..::: For This Useful Post: |
04-01-2011, 15:06 | #39 (permalink) |
No Life Poster Join Date: Apr 2010 Location: U.K. / INDIA
Member: 1283682 Status: Offline Thanks Meter: 304 | File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM22 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending modem.bin... OK Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM21) Read Phone Info Fail Done with Samsung 3G tool ver 9.4 but when it turns ON and than I clicked UNLOCK SP .. this error comes ...? |
The Following User Says Thank You to C Singh For This Useful Post: |
05-24-2011, 16:24 | #42 (permalink) |
Freak Poster Join Date: Jan 2002 Location: sp coastline
Member: 8802 Status: Offline Thanks Meter: 16 | I faced the same problem. Windows didn't recognize the download mode but after few tries it appears on z3x prog, not in windows, but works fine. After that all codes at 00000000, input them and error, but phone is unlocked after reset. BR |
06-19-2011, 10:15 | #43 (permalink) | |
Junior Member Join Date: Jun 2011
Member: 1600238 Status: Offline Thanks Meter: 0 | Quote:
06-27-2011, 15:08 | #44 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 236460 Status: Offline Thanks Meter: 61 | File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM38 Opening Port... OK Setup connection... Error Done with Samsung 3G tool ver 9.4 can't unlock galaxy p1000 please help |
06-27-2011, 15:09 | #45 (permalink) |
Member: 236460 Status: Offline Thanks Meter: 61 | please help me unlock this phone galaxy p1000 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM38 Opening Port... OK Setup connection... Error Done with Samsung 3G tool ver 9.4 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
