Old 08-07-2016, 10:19   #1 (permalink)
Member: 1931004
Sonork: 100.1662382
Thanks Meter: 85
GT-S5611 Hard reset/Security unlocked Successfuly
when you have/received GT-S5611 phone at hand requesting for phone lock, then here is an indirect way of how to solved it.
required:
Z3X Samsungtool or Pro edition
Micro USB-Cable
*2767*3855#
* Power on the phone to show phone lock screen and connect it to PC .
* Check device manager and install driver if needed .
* Open Z3X Samsung tool choose S5611, and unlocked by checking normal mode and choosing Samsung Mobile USB Serial Port.
* After unlock done, Turn off the phone and quickly turn it on, when ask for unlock code just cancel and for the first time you may be able to access the home screen and then dial *2767*3855# and that will reset your phone to factory removing the phone lock code.
You may say why following this long process while there is an option in recent Z3x Pro or just flash the phone and that's all. believe me sometimes dealing with spd ain't easy when it comes to driver issue and you cant work with it easily with 64-bit PC, so since am not pro @it even flashing this phone is hard for me.
but through this method i easily solve my issue with even windows 10 64-bit.
The Following User Says Thank You to binadam23 For This Useful Post:
Page generated in 0.12327 seconds with 8 queries
