09-04-2015, 17:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | GT-S5830D read code done by 22.4 for easy boy UART cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose phone USB. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: GT-S5830D Selected port: COM22 SAMSUNG Android USB Diagnostic Serial Port (WDM) Software version: 22.4 Checking phone at COM22 Reading phone info... OK Model: GT-S5830D Country code: ij³ª´Ù / TLS Cal date: 2011-09-15 Factory SW: S5830DTLKI4_TLSKI4 Unique number: 23580000054551 Memory phone: KAT007012B(S5830) Phone S/N: R21C54Y6DV PDA/CSC version: S5830DTLKI4/S5830DTLSKI4 Phone version: S5830DTLKI4 Phone HW: REV1.0 Cal date: 2012.05.24 Reading IMEI... OK IMEI: 359079042757519 Reading security... OK Bypass MSL... OK Reading codes... OK Freeze code: 03737597 NET lock: 95248209 Sub lock: 00000000 SP lock: 95248209 CP lock: 00000000 For check lock status: *#7465625# |
The Following User Says Thank You to ghacks For This Useful Post: |
