03-03-2018, 09:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | GT-S7560 port not selectedbut adb selectbox only Code: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-S7560 Software version: 30.7 Port not selected Done with Samsung Tool PRO v.30.7 |
