03-20-2010, 18:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Gu230 read code ok Direct unlock problem Analising EEPROM... Phone IMEI:3572xxxxxxxx Unlock codes: NCK[0]: 0000000000000000 (UNLOCKED) NCK[1]: 0000000000000000 (UNLOCKED) NCK[2]: 0000000000000000 (UNLOCKED) NCK[3]: 5555070801175637 (UNLOCKED) NCK[4]: 5555070801175637 (UNLOCKED) NCK[5]: 5555070801175637 (UNLOCKED) NCK[6]: 5555070801175637 (UNLOCKED) NCK[7]: 5555070801175637 (UNLOCKED) Finished in 21 seconds Opening "GU230_autobackup_19032010_162319.eep"... Erasing EEPROM... Sending SEC pack... Erasing done! Writing EEPROM... Sending SEC pack... Writing done! Finished in 20 seconds Program succesfully Direct Unlock ok but yellow screen > Connecting to GU230 in UART Mode (COM6 ,921600) 19/03/2010 16:22:12 > Please reconnect battery, press and hold power button... 19/03/2010 16:22:23 > Phone found! (MCU:UNK:FE) prebooting... 19/03/2010 16:22:23 > Release power button. Booting... 19/03/2010 16:22:27 > Reading info... 19/03/2010 16:22:28 > Flash ID: 0x8981 19/03/2010 16:22:28 > BOOT Stage Finished , sending authority... 19/03/2010 16:22:28 > Sending SEC pack... 19/03/2010 16:22:28 > Reading ... 19/03/2010 16:22:28 > Sending SEC pack... 19/03/2010 16:22:48 > Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GU230_autobackup_19 032010_162248.eep 19/03/2010 16:22:48 > Analising EEPROM... 19/03/2010 16:22:49 > Phone IMEI:xxxxxxxx 19/03/2010 16:22:49 > Unlock codes: 19/03/2010 16:22:49 > NCK[0]: 0000000000000000 (UNLOCKED) 19/03/2010 16:22:49 > NCK[1]: 0000000000000000 (UNLOCKED) 19/03/2010 16:22:49 > NCK[2]: 0000000000000000 (UNLOCKED) 19/03/2010 16:22:49 > NCK[3]: 5555070801175637 (UNLOCKED) 19/03/2010 16:22:49 > NCK[4]: 5555070801175637 (LOCKED) 19/03/2010 16:22:49 > NCK[5]: 5555070801175637 (LOCKED) 19/03/2010 16:22:49 > NCK[6]: 5555070801175637 (LOCKED) 19/03/2010 16:22:49 > NCK[7]: 5555070801175637 (LOCKED) 19/03/2010 16:22:49 > Finished in 21 seconds 19/03/2010 16:22:59 > Unlocking... 19/03/2010 16:22:59 > Sending SEC pack... 19/03/2010 16:23:00 > Reading EEPROM.... 19/03/2010 16:23:19 > Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GU230_autobackup_19 032010_162319.eep 19/03/2010 16:23:19 > Analising EEPROM... 19/03/2010 16:23:20 > Phone IMEI:3572450306815890 19/03/2010 16:23:20 > SimLock Data Cleared! 19/03/2010 16:23:20 > Sending SEC pack... 19/03/2010 16:23:21 > Erasing EEPROM.... 19/03/2010 16:23:29 > Erasing done! 19/03/2010 16:23:29 > Writing EEPROM.... 19/03/2010 16:23:29 > Sending SEC pack... 19/03/2010 16:23:41 > Unlock done! 19/03/2010 16:23:41 > Finished in 41 seconds |
03-20-2010, 19:18 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
05-10-2010, 10:58 | #5 (permalink) | |||
Freak Poster Join Date: Dec 2004 Location: BiH Age: 43
Member: 100770 Status: Offline Thanks Meter: 57 | Quote:
flash with: Quote:
then again flashed full flash with: Quote:
for destroying phones I have "hammer box" and "throw threw the window clip"...but z3x i need for unlock and repair...so please do assist | |||
05-10-2010, 14:02 | #6 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
Hello , try to write this one EEPROM if all will be okay we try to do something ;-) | |
05-10-2010, 15:20 | #7 (permalink) | ||
05-10-2010, 16:09 | #8 (permalink) |
Member: 100770 Status: Offline Thanks Meter: 57 | PMB8810 Module 1.1 started. SW: Ver 2.2.4.2 Connecting to GU220 in UART Mode (COM4 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Release power button. Booting... Reading info... Flash ID: 0x8981 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Sending SEC pack... Analising EEPROM... Phone IMEI:3572450303448320 Unlock codes: NCK[0]: 0000000000000000 (UNLOCKED) NCK[1]: 0000000000000000 (UNLOCKED) NCK[2]: 6648858652679483 (UNLOCKED) NCK[3]: 6648858652679483 (UNLOCKED) NCK[4]: 6648858652679483 (UNLOCKED) NCK[5]: 6648858652679483 (UNLOCKED) Finished in 14 seconds Opening "GU230AT-00-V10f-CIS-XXX-NOV-10-2009+0.bin"... Erasing Firmware... Sending SEC pack... Erasing done! Writing Firmware... Sending SEC pack... Writing done! Finished in 34 minutes 43 seconds. the catch was to enable "full erase" and to flash it like this under: sg3 codeo...SG3_1GFULL and without erase didnt worked... |
05-11-2010, 15:03 | #9 (permalink) |
Insane Poster Join Date: Feb 2001 Location: Hungary Age: 43
Member: 3408 Status: Offline Thanks Meter: 3 | Reading phone information ( must be powered ON! Phone platform:INFINEON Phone IMEI:3572xxxxxxxxxxxxx Phone S/N:3572xxxxxxxxxxxxx Phone SW VER.:GU230AT-01-V10a-216-70-APR-8-2010+0 Phone HW VER.:1.0 Phone LCD Revision:LCD B1.1 Phone Camera Revision:CAM 1.0 Bluetooth Adress:6cd68aa6f13a Net Lock Conf:"1","216,70F,FFFFFFFF,FFFFFFFF,FF" SIM Lock Conf:"1","216,70F,FFFFFFFF,FFFFFFFF,FF" Battery Voltage:3.9V Done! PMB8810 Module 1.1 started. SW: Ver 2.2.4.2 Connecting to GU230 in UART Mode (COM4 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Preloader answer failed... BOOT Failed Disconnected. |
05-13-2010, 04:15 | #10 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 235759 Status: Offline Thanks Meter: 162 | I've received 3 pieces, I unlocked 1 very well by making cable as in picture, but the others always failed connection: PMB8810 Module 1.1 started. SW: Ver 2.2.4.2 Connecting to GU230 in UART Mode (COM3 ,115200) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Preloader answer failed... BOOT Failed Disconnected. I use same connection method, but just working on the first Please help us, Vygis already implemented USB connections Thanks in advance |
05-14-2010, 15:11 | #13 (permalink) |
Member: 100770 Status: Offline Thanks Meter: 57 | quite strange...because when phone is turned on you have conection...did you tryed to change cable (gw300 uart), solder new wires (even if you have conection for reading phone), write first flash and e2p then unlock...or even on other tool?! |
Unlock e1085 Direct Unlock * Not Read Codes Ok [REPORT OK] | WILUNLOCK | PolarBox 3 | 1 | 12-07-2009 21:26 |
Unlocking by Read code and Direct,the diference...... | yentrang120705 | Easy-Unlocker | 1 | 05-17-2009 18:29 |
Samsung E800, can read codes, but can't unlock directly | laxxe | n-Box | 5 | 01-16-2008 08:28 |
Moto C123 Read Code OK But Direct Unlock No | tcom25100 | PolarBox 3 | 1 | 12-15-2007 16:19 |
Z105 or Z107 unlock problem sw read code ok | simlockman1 | NSPRO | 4 | 10-15-2005 14:18 |
