02-14-2014, 14:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | [GUIDE] i9195 New Security with KNOX - Repair & unlock DONE! 100% 1. Flash phone with ODIN with I9195XXUBMJ7_OXABMJ7 firmware, downloaded from z3x support. 2. After flash do factory reset (wipe data, cache in recovery meny) 3. Turn on the phone do go through basic setup, enable usb debuging 4. Download this file: https://mega.co.nz/#!1tVVRSgY!3zUEZ7...clude file key 5. Copy the file into to phone. 6. Download this file https://mega.co.nz/#!GopgFJ4R!WsNnv2...AM0EFdECa-FuDY 7. Flash the recovery-clockwork-6.0.4.6-serranoltexx.tar.md5 with odin into PDA section, SOON AS ODIN SAYS DONE AND PHONE VIBRATES, HOLD VOLUME UP AND HOME BUTTON to go into recovery. 8. In recovery flash GT-I9195_RootKit_v2 which u copied into the phone in step 5 9. Reboot the phone, press *#8080# and select DM+MODEM+ADB, press OK. 10. Conect phone to usb, istall drivers 11. In z3x tool select samsung modem port-NOT BOX UART PORT. 12. Click Repair, fill the imei and let the z3x do the job. After success imei repair, turn phone off and back on (NOT WITH REMOVING BATTERY) 13. All done, if u want u can reflash phone with latest stock fw with knox. LOG: Code: Selected model: I9195 Selected port: COM11 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZKABTU Phone version: I9195XXUBMJ7 PDA version: I9195XXUBMJ7 CSC version: I9195OXABMJ7 IMEI: 356845255547893 Phone S/N: R31DB1LAG6E Checking phone at COM11 OK Backuping NVM... OK Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM11 OK Repairing IMEI... OK Restoring NVM... OK Reseting... OK Repair done Done with Samsung Tool v.16.9 |
The Following 7 Users Say Thank You to Thorenzz For This Useful Post: |
02-19-2014, 16:01 | #3 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | this ROOT method does not need to use, you can via VRoot in the 3sec success... BR, Dicle_Gsm |
The Following User Says Thank You to dicle_gsm For This Useful Post: |
02-19-2014, 19:22 | #6 (permalink) |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | If u follow all the steps exactly as i said in guide i am sure it will work....if not check if usb debuging enabled, check if drivers installed properly and also make sure that u keep ur phone screen unlocked so u can see super user requests on the phone screen. sent from my Xperia Z1 using Tapatalk 2. |
02-21-2014, 10:19 | #13 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Update Superuser? May be that work - I had issue with two models KingO Root Is Useless with this model so do not try that! however the 3rd one worked: Code: Selected model: I9195 Selected port: COM268 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZWAEVR Phone version: I9195XXUAMF5 PDA version: I9195XXUAMF5 CSC version: I9195EVRAMF6 IMEI: 35827XXXXXXXXXXX Phone S/N: RF1DB5N8DFH Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM268 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Unlocking... OK Checking phone at COM268 Restoring NVM... OK Reseting... OK Unlock done Done with Samsung Tool v.17.0 Last edited by shak360; 02-21-2014 at 10:28. |
02-21-2014, 10:55 | #14 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | This is just a small theory but i think the problem lies to where the root is installed on the phone because of knox - and because its located in a different location maybe this is why z3x can not locate the root .. because tradditionally it is installed in the system/app folder however i remember reading it in the xda-dev forum its installed in a different location to gain root access/priviliges this is where the issue may lie???? Then again why would it work on some handsets and not others :/ =( |
02-21-2014, 15:05 | #15 (permalink) |
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | DONE DONE THX Selected model: I9195 Selected port: COM380 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZWALUX Phone version: I9195XXUAMH4 PDA version: I9195XXUAMH4 CSC version: I9195LUXAMG2 IMEI: 358270052 Phone S/N: RF1D92VBDQN Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.17.0 Selected model: I9195 Selected port: COM380 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZWALUX Phone version: I9195XXUAMH4 PDA version: I9195XXUAMH4 CSC version: I9195LUXAMG2 IMEI: 3582700 Phone S/N: RF1D92VBDQN Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM380 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Unlocking... OK Checking phone at COM380 Restoring NVM... OK Reseting... OK Unlock done Done with Samsung Tool v.17.0 DONE DONE THX |
