06-05-2016, 21:15 | #1 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Davie Florida
Member: 1745565 Status: Offline Thanks Meter: 14 | [GUIDE] Samsung Mega 2 G750A 5.1.1 How to First you are going to need the 5.1.1 firmware GUIDE IS ONLY FOR 5.1.1 FIRMWARE!!! DOWNLOAD HERE WARNING!!! Using this method will soft brick your device PROCEED AT YOUR OWN RISK I AM NOT RESPONSIBLE FOR ANY HARD BRICKS!!! Download the firmware and extract it. Next download Kingo Root APK directly to your phone. Enable USB Debugging and Enable Diag Mode *#0808# Next Root your phone using the Kingo Root APK VERY IMPORTANT!!! DO NOT REBOOT AFTER ROOT IS COMPLETE Connect it to Z3x and Proceed with the unlock. Once it reboots the phone it will be stuck on a bootloop. Thats ok as long as z3x has a chance to pick up the device. make sure that it reconnects to Z3x and you should see it reset the MSL etc.. Once that process is done you will see it failed to unlock. if you did everything correctly when you put in a non supported sim it should not reject. Now your phone will be permanently unlocked. To get out of the bootloop, put the phone in download mode and flash the firmware I provided. ======================= I will try to provide support for you guys in this thread so post here and when I get on I will try to help you. Good luck... |
06-08-2016, 11:43 | #4 (permalink) |
Member: 1745565 Status: Offline Thanks Meter: 14 | Bump. The file has been uploaded. If you guys need my help let me know and as soon as I can I will reply and try to help. Sent from my SM-N920T using Tapatalk |
11-25-2016, 19:41 | #5 (permalink) |
Insane Poster Join Date: Mar 2014 Location: United States, Irving
Member: 2156601 Status: Offline Thanks Meter: 3 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G750A Software version: 27.1 Waiting ADB device... Please, allow USB debugging on phone... ok Reading phone info... Model: SAMSUNG-SM-G750A Android version: 5.1.1 Product code: SM2G750ANKAATT Phone version: G750AUCU3BOH4 PDA version: G750AUCU3BOH4 CSC version: CSC country code: CSC sales code: HW version: REV0.3 Phone SN: R38G70704GB Modem board: DB7450R RF cal date: 2015.07.16 IMEI: Checking Super user right... true Reading NV data... ok Analyzing NV data... ok Writing NV Data... ok Rebooting phone... ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.1 Basically it doesn't reconnect to adb...so operation timed out. |
