03-10-2018, 21:53 | #946 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2506474 Status: Offline Thanks Meter: 21 | j327 rev2 unlock by diag port not supported Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever ('Diag' algo): Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever ('Upload' algo): Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J327A Software version: 30.9 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM498 Reading phone info... OK Model: SM-J327A AP version: J327AUCS2ARA1 CSC version: J327AATT2ARA1 CP version: J327AUCS2ARA1 Product code: ATT Phone SN: R28JC0QZ9CH Unique number: CQ300443EE4F4B4 Searching Samsung diag port... detected COM497 Reading phone info... OK CP version: J327AUCS2ARA1 CP build: Jan 9 2018 12:16:59 Reading data from phone... error (1) Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.30.9 |
03-15-2018, 09:05 | #948 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2821242 Status: Offline Sonork: wws330 Thanks Meter: 0 | Software version: 30.8 Reading phone info...OK Model: SM-N935F AP version: N935FXXS2ARA1 CSC version: N935FOLB1AQI5 CP version: N935FXXU2ARA1 CP build: Jan 3 2018 14:03:03 Product code: XME Reading phone info...OK Reading data from phone...error (1) |
03-24-2018, 10:53 | #952 (permalink) |
Freak Poster Join Date: Oct 2010 Location: indore
Member: 1409652 Status: Offline Sonork: 100.1670588 Thanks Meter: 76 | If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 Product code: SM-G935FZKUINS Phone version: G935FXXU2DRAG PDA version: G935FXXU2DRAG CSC version: G935FODD2DRAG CSC country code: India CSC sales code: INS HW version: MP 0.801 Phone SN: RF8H31RC88Y Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2018-01-01 RF cal date: 20160511 IMEI: 357327070336843 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.31.0 MR BLANG pls solved my prob sm-g935fd binarry 2 not downgrade how to network repaire |
03-24-2018, 13:22 | #953 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | issue in setup for z3x pro 31 version microsoft essentrial security not allow to open after install. its detected as malware/thread/virus/ please check from your side. thanks. |
03-24-2018, 13:23 | #954 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | I have teseted three phone, same issue for Phone version: G955USQU2CRB9, version 8.0 Operation: Unlock Selected model: SM-G955U Software version: 31.0 Checking Login and Password... OK Ballance: 55 crd. You have 55 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 Product code: SM-G955UZKATMB Phone version: G955USQU2CRB9 PDA version: G955USQU2CRB9 CSC version: G955UOYN2CRB9 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J5266LRP Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-02-01 RF cal date: 2017.05.18 IMEI: 355980083112775 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (3.) Done with Samsung Tool PRO v.31.0 |
03-27-2018, 06:34 | #956 (permalink) |
Freak Poster Join Date: Apr 2012 Location: phone unlocking service
Member: 1752476 Status: Offline Sonork: 1615329 Thanks Meter: 16 | j701f cost credit butt no code 3/26/2018 2:53:00 PM ] Operation: Read Codes via Server [ 3/26/2018 2:53:00 PM ] Selected model: SM-J701F [ 3/26/2018 2:53:00 PM ] Software version: 31.0 [ 3/26/2018 2:53:00 PM ] [ 3/26/2018 2:53:00 PM ] Checking Login and Password... OK [ 3/26/2018 2:53:00 PM ] Ballance: 50 crd. [ 3/26/2018 2:53:00 PM ] You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes [ 3/26/2018 2:53:00 PM ] Searching Samsung modem... detected COM184 [ 3/26/2018 2:53:00 PM ] Reading phone info... OK [ 3/26/2018 2:53:00 PM ] Model: SM-J701F [ 3/26/2018 2:53:00 PM ] AP version: J701FXXU3ARA4 [ 3/26/2018 2:53:00 PM ] CSC version: J701FOJV3ARA4 [ 3/26/2018 2:53:00 PM ] CP version: J701FXXU3ARA3 [ 3/26/2018 2:53:00 PM ] Product code: XSG [ 3/26/2018 2:53:00 PM ] Phone SN: RZ8K12ABPXW [ 3/26/2018 2:53:00 PM ] Unique number: CAJ0027B4C03EC4 [ 3/26/2018 2:53:00 PM ] Searching Samsung diag port... detected COM183 [ 3/26/2018 2:53:00 PM ] Reading phone info... OK [ 3/26/2018 2:53:00 PM ] CP version: J701FXXU3ARA3 [ 3/26/2018 2:53:00 PM ] CP build: Jan 11 2018 19:02:19 [ 3/26/2018 2:53:00 PM ] Reading data from phone... error (1) [ 3/26/2018 2:53:00 PM ] Searching server... OK [ 3/26/2018 2:53:00 PM ] Checking available files... OK [ 3/26/2018 2:53:00 PM ] Available CP file for downgrade, try download and flash? Continue? Yes [ 3/26/2018 2:53:00 PM ] Downloading file... OK [ 3/26/2018 2:56:00 PM ] Checking local file... OK [ 3/26/2018 2:56:00 PM ] Switching to flash mode... OK [ 3/26/2018 2:56:00 PM ] Searching USB Flash interface... COM53 detected [ 3/26/2018 2:56:00 PM ] Setup connection... OK [ 3/26/2018 2:56:00 PM ] Reading data from phone... OK [ 3/26/2018 2:56:00 PM ] Sending data to phone... OK [ 3/26/2018 2:56:00 PM ] Searching Samsung modem... detected COM184 [ 3/26/2018 2:57:00 PM ] Reading phone info... OK [ 3/26/2018 2:57:00 PM ] Model: SM-J701F [ 3/26/2018 2:57:00 PM ] AP version: J701FXXU3ARA4 [ 3/26/2018 2:57:00 PM ] CSC version: J701FOJV3ARA4 [ 3/26/2018 2:57:00 PM ] CP version: J701FXXU3ARA1 [ 3/26/2018 2:57:00 PM ] Product code: XSG [ 3/26/2018 2:57:00 PM ] Phone SN: RZ8K12ABPXW [ 3/26/2018 2:57:00 PM ] Unique number: CAJ0027B4C03EC4 [ 3/26/2018 2:57:00 PM ] Searching Samsung diag port... detected COM183 [ 3/26/2018 2:57:00 PM ] Reading phone info... OK [ 3/26/2018 2:57:00 PM ] CP version: J701FXXU3ARA1 [ 3/26/2018 2:57:00 PM ] CP build: Jan 3 2018 14:19:14 [ 3/26/2018 2:57:00 PM ] Reading data from phone... OK [ 3/26/2018 2:58:00 PM ] Calculating... OK [ 3/26/2018 2:58:00 PM ] Searching server... [ 3/26/2018 3:13:00 PM ] Operation: Read Codes via Server [ 3/26/2018 3:13:00 PM ] Selected model: SM-J701F [ 3/26/2018 3:13:00 PM ] Software version: 31.0 [ 3/26/2018 3:13:00 PM ] [ 3/26/2018 3:13:00 PM ] Checking Login and Password... OK [ 3/26/2018 3:13:00 PM ] Ballance: 45 crd. [ 3/26/2018 3:13:00 PM ] You have 45 credit(s) left. This operation takes 5 credits.Continue? No |
03-27-2018, 07:44 | #957 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | t-mobile device unlock app s8 new security not supproted Operation: Unlock Selected model: SM-G950U Software version: 31.0 Checking Login and Password... OK Ballance: 150 crd. You have 150 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 Product code: SM-G950UZKATMB Phone version: G950USQU2CRB9 PDA version: G950USQU2CRB9 CSC version: G950UOYN2CRB9 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J41F644L Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-02-01 RF cal date: 2017.04.13 IMEI: 355987081582362 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (3.) Done with Samsung Tool PRO v.31.0 --- |
03-27-2018, 14:00 | #958 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | NOT SUPPORTED Product code: SM-G955UZKATMB, PDA version: G955USQU2CRB9 - T-MOBILE DEV LATEST FIRMWARE 8.0 NOT SUPPORTED - NOT SUPPORTED Product code: SM-G955UZKATMB, PDA version: G955USQU2CRB9 - T-MOBILE DEVICE UNLOCK APP Operation: Unlock Selected model: SM-G955U Software version: 31.0 Checking Login and Password... OK Ballance: 125 crd. You have 125 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 Product code: SM-G955UZKATMB Phone version: G955USQU2CRB9 PDA version: G955USQU2CRB9 CSC version: G955UOYN2CRB9 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J42D1YLF Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-02-01 RF cal date: 2017.04.19 IMEI: 355980081933644 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (3.) Done with Samsung Tool PRO v.31.0 |
03-28-2018, 08:34 | #959 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | again new phone - s8 not supported, new security and firmware S8 T-mobile device unlock app, not supported for unlock Operation: Unlock Selected model: SM-G950U Software version: 31.0 Checking Login and Password... OK Ballance: 115 crd. You have 115 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 Product code: SM2G950UZKATMB Phone version: G950USQU2CRB9 PDA version: G950USQU2CRB9 CSC version: G950UOYN2CRB9 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: RF8JA14A2HP Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-02-01 RF cal date: 2017.10.09 IMEI: 353111090822071 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (3.) Done with Samsung Tool PRO v.31.0 |
03-29-2018, 07:36 | #960 (permalink) |
Major Poster Join Date: May 2014
Member: 2190317 Status: Offline Thanks Meter: 9 | t mobile app lock locked back after 30 days sir after unlocking samsung j327t it locked back after 30days customer called after 30days to inform me that phone locked back he has not been in town came back last weekend with phone and i checked it its true. the log i saved is still in my system. i can show video proof if required . my log in id zsc_1BkdXo8p Operation: Unlock Selected model: SM-J327T Software version: 30.5 Checking Login and Password... could not connect to server Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J327T Android version: 7.0 Product code: SM2J327TZKATMB Phone version: J327TUVU1AQCB PDA version: J327TUVU1AQCB CSC version: J327TTMB1AQCB CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R28J52S910V Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-03-01 RF cal date: 20170523 IMEI: 355xxxxxxxxx515 Searching Samsung diag port... detected COM239 Reading phone info... OK CP version: J327TUVU1AQCB CP build: Mar 23 2017 16:50:58 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
