Old 03-21-2016, 19:42   #496 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
z3x samsung: Help Instructions is empty after select s7 or s7 edge modell
Great update z3x team.
would like to share below things.
FOR S7 AND S7 EDGE, NEW ADDED MODEL
When we are going to select model for s7 or s7 edge, help option is emply, there is not any instructions avilable.
INSTRUCTIONS IS NOT AVAILABLE IN EACH TAB OF SAMSUNG TOOL PRO 24.9
HELP: ITS EMPTY - UNLOCK, REPAIR, DOWNLOAD, BAKCUP
Help files not available
The Following User Says Thank You to creconinfo For This Useful Post:
Old 03-22-2016, 05:13   #497 (permalink)
Member: 92260
Thanks Meter: 809
Originally Posted by gsmking420 View Post
i repaired imei on sm-n920t to its original imei then i patched it everything works fine but it keeps turning off after talking for two minutes straight. in the middle of the call it reboots.. any help???
Most likely the DRK (developer root key) is damaged.
Check it by going into recovery mode and look at the bottom of the screen for something like "DRK fail"
You will need to fix it.
Old 03-24-2016, 22:18   #498 (permalink)
Crazy Poster
Member: 337158
Thanks Meter: 9
Waiting ADB device... OK
Reading phone info...
Model: SM-G928F
Android version: 6.0.1
Product code: SM-G928FZKASER
Phone version: G928FXXU2BPB6
PDA version: G928FXXU2BPB6
CSC version: G928FOXE2BPB6
CSC country code: Russia
CSC sales code: SER
HW version: MP 0.500
Phone S/N: R58H12YGFZZ
Modem board: SHANNON333
RF cal date: 20160123
IMEI:
Checking Super user right... true
Initializating zTool... OK
Running zTool, please wait...
Start... OK
Init... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Unlocking...
Exception: Access violation at address 0040744F in module 'SamsungToolPRO.exe'. Read of address 0BB35F2C
Done with Samsung Tool PRO v.24.9
Old 04-04-2016, 12:07   #499 (permalink)
Member: 951592
Thanks Meter: 12
Hi,
N920C note 5 FRP lock cannot remove.
Version 6.0 Marshmallow. Not supported?
Old 04-07-2016, 14:31   #500 (permalink)
Member: 363265
Sonork: 100.1648064
Thanks Meter: 57
i have G531F working very slow.....
i make hard reset ..after that set hang on logo...
i flash with 4 files now set alive..
but no imei ... BB ok...
i try to write cert but always get BYPASS MSL ERROR
set not make diag port
*#06# *#0808# *#9090# all code not working
i try apk to activiting diag port using apk but unable to make diag port
i try reset efs also ...but problem same
try lots of firmawers but same
use prerooted firmware
i use Z3X pro all versions but after all that problem is same.....
Old 04-07-2016, 14:46   #501 (permalink)
smkab143's Avatar
Member: 1830045
Thanks Meter: 39
samsung B360e after flash with z3x set is blinking, and not recover
Old 04-07-2016, 15:04   #502 (permalink)
Member: 372482
Thanks Meter: 93
B2100i can't flash whole flash
FLASH INSTRUCTIONS:
  1. Choose correct flash file(s).
     CSC can not be flashed separately, without main PTT file.
  2. Press 'Flash' button.
  3. Connect phone in flash mode (press '1'+'2' button and connect USB cable).
Operation: Flash
Selected model: GT-B2100I
Software version: 25.0
Load model info... OK
Loading BIN PTT file... OK
Loading CSC PTT file... OK
Reconnect battery and connect phone to USB cable
Phone detected
Checking device descriptions... error
Flashing done (time - 00:00:11)
Done with Samsung Tool PRO v.25.0
Old 04-07-2016, 16:00   #503 (permalink)
Member: 2189329
Thanks Meter: 8
Sm-g935t
Please add unlock for SM-G935T
Old 04-08-2016, 16:40   #504 (permalink)
Member: 2538390
Thanks Meter: 24
helo,,i did not find f120s,,in model list,,,,whyyyyyyyyyyyyyy?????/
Old 04-12-2016, 12:10   #505 (permalink)
Crazy Poster
Member: 337158
Thanks Meter: 9
version 25.1
Operation: Unlock
[ 11.04.2016 14:09:00 SM-G903F ] Selected model: SM-G903F
[ 11.04.2016 14:09:00 SM-G903F ] Software version: 25.1
[ 11.04.2016 14:10:00 SM-G903F ] Waiting ADB device... OK
[ 11.04.2016 14:10:00 SM-G903F ] Reading phone info...
[ 11.04.2016 14:10:00 SM-G903F ] Model: SM-G903F
[ 11.04.2016 14:10:00 SM-G903F ] Android version: 5.1.1
[ 11.04.2016 14:10:00 SM-G903F ] Product code: SM-G903FZKAEVR
[ 11.04.2016 14:10:00 SM-G903F ] Phone version: G903FXXU1AOI5
[ 11.04.2016 14:10:00 SM-G903F ] PDA version: G903FXXU1AOI2
[ 11.04.2016 14:10:00 SM-G903F ] CSC version: G903FEVR1AOH2
[ 11.04.2016 14:10:00 SM-G903F ] CSC country code: UK
[ 11.04.2016 14:10:00 SM-G903F ] CSC sales code: EVR
[ 11.04.2016 14:10:00 SM-G903F ] HW version: MP 0.500
[ 11.04.2016 14:10:00 SM-G903F ] Phone S/N: RF8GB0AFZCX
[ 11.04.2016 14:10:00 SM-G903F ] Modem board: SHANNON310
[ 11.04.2016 14:10:00 SM-G903F ] RF cal date: 20151104
[ 11.04.2016 14:10:00 SM-G903F ] IMEI:
[ 11.04.2016 14:10:00 SM-G903F ] Checking Super user right... true
[ 11.04.2016 14:10:00 SM-G903F ] Reading nv data... OK
[ 11.04.2016 14:10:00 SM-G903F ] Checking NV data... error
[ 11.04.2016 14:10:00 SM-G903F ] Security damaged (1)
version 25.0
[ 11.04.2016 14:13:00 SM-G903F ] Operation: Unlock
[ 11.04.2016 14:13:00 SM-G903F ] Selected model: SM-G903F
[ 11.04.2016 14:13:00 SM-G903F ] Software version: 25.0
[ 11.04.2016 14:13:00 SM-G903F ] Waiting ADB device... OK
[ 11.04.2016 14:13:00 SM-G903F ] Reading phone info...
[ 11.04.2016 14:13:00 SM-G903F ] Model: SM-G903F
[ 11.04.2016 14:13:00 SM-G903F ] Android version: 5.1.1
[ 11.04.2016 14:13:00 SM-G903F ] Product code: SM-G903FZKAEVR
[ 11.04.2016 14:13:00 SM-G903F ] Phone version: G903FXXU1AOI5
[ 11.04.2016 14:13:00 SM-G903F ] PDA version: G903FXXU1AOI2
[ 11.04.2016 14:13:00 SM-G903F ] CSC version: G903FEVR1AOH2
[ 11.04.2016 14:13:00 SM-G903F ] CSC country code: UK
[ 11.04.2016 14:13:00 SM-G903F ] CSC sales code: EVR
[ 11.04.2016 14:13:00 SM-G903F ] HW version: MP 0.500
[ 11.04.2016 14:13:00 SM-G903F ] Phone S/N: RF8GB0AFZCX
[ 11.04.2016 14:13:00 SM-G903F ] Modem board: SHANNON310
[ 11.04.2016 14:13:00 SM-G903F ] RF cal date: 20151104
[ 11.04.2016 14:13:00 SM-G903F ] IMEI:
[ 11.04.2016 14:13:00 SM-G903F ] Checking Super user right... true
[ 11.04.2016 14:13:00 SM-G903F ] Reading nv data... OK
[ 11.04.2016 14:13:00 SM-G903F ] Checking NV data... OK
[ 11.04.2016 14:13:00 SM-G903F ] Unlocking... OK
[ 11.04.2016 14:13:00 SM-G903F ] Rebooting phone... OK
[ 11.04.2016 14:13:00 SM-G903F ] Unlock done
Old 04-12-2016, 18:34   #506 (permalink)
Member: 2419703
hi, i am having some issues with n910t3 and n910t on5.1.1 basband DOK2 I WAS TRYING TO DO IMEI REPAIR BUT I GOT MSL ERROR WHEN I RESET MSL I STILL GET THE SAME ERROR. ANY HELP PLEASE .
Old 04-13-2016, 02:18   #507 (permalink)
Member: 2145583
Thanks Meter: 7
PlEase add sony c6943
Old 04-14-2016, 19:23   #508 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
sm-n920t 5.1.1 - unlock not worked
Model: SM-N920T
Product code:
Phone version:
PDA version: N920TUVS2COKC
CSC version: N920TTMB2COKC
CSC country code: USA
CSC sales code: TMB
HW version:
Phone S/N: RF8G82K9SZZ
Modem board:
RF cal date:
IMEI:
Start... OK
Init... OK
Reading data... error (8)
Done with Samsung Tool PRO v.25.1
Old 04-22-2016, 12:33   #509 (permalink)
Member: 2464525
Sonork: jsolisdc
Thanks Meter: 3
Add Nexus 6p
Sent from my Nexus 6P using Tapatalk
Old 04-22-2016, 20:08   #510 (permalink)
Member: 1972820
Security damaged (1) reading code or unlocking. the same issue.
Model: SM-J700M
Product code: SM-J700MZKACDR
Phone version: J700MUBU1APA5
PDA version: J700MUBU1APA5
CSC version: J700MUWA1APA5
CSC country code: Dominican Republic
CSC sales code: CDR
HW version: MP 0.700
Phone S/N: R28H32VB9KX
RF cal date: 20160322
IMEI:
Done with Samsung Tool PRO v.25.2
Checking hash file... OK
Model: SM-J700M
CSC sales code: CDR
IMEI:
Page generated in 0.40679 seconds with 8 queries
