08-25-2016, 05:22 | #590 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Android version: 6.0.1 PDA version: G920FXXS3DPF4 CSC version: G920FOXE3DPE1 Modem board: RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched | |
08-26-2016, 09:47 | #591 (permalink) | |
Insane Poster Join Date: Jul 2012
Member: 1791766 Status: Offline Thanks Meter: 2 | Quote:
G925f same. Please PG1, PG8 modems patch Samsung has closed the downgarde 6.0.1 to 5.1.1 OJ1 modem does not work 6.0.1 software | |
10-08-2016, 13:24 | #593 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2086857 Status: Offline Sonork: gsmboss Thanks Meter: 0 | hello i try frp remove for g930f [ 10/8/2016 1:28:00 PM ] Operation: Reset FRP/React/EE [ 10/8/2016 1:28:00 PM ] Selected model: SM-G930F [ 10/8/2016 1:28:00 PM ] Software version: 26.9 [ 10/8/2016 1:28:00 PM ] [ 10/8/2016 1:28:00 PM ] Checking local file... OK [ 10/8/2016 1:28:00 PM ] Searching server... OK [ 10/8/2016 1:28:00 PM ] Compare local and server file... OK (up to date) [ 10/8/2016 1:28:00 PM ] Searching USB Flash interface... COM109 detected [ 10/8/2016 1:28:00 PM ] Setup connection... OK [ 10/8/2016 1:28:00 PM ] Reading data from phone... OK [ 10/8/2016 1:28:00 PM ] Sending data to phone... OK [ 10/8/2016 1:28:00 PM ] Waiting ADB device... timeout [ 10/8/2016 1:31:00 PM ] Phone not found after s7 is lock on boot logo samsung galaxy s7 s7 dont wont go to download mode cant flash it help me please URGENT !! sorry for my english thaks you !! |
10-14-2016, 12:15 | #595 (permalink) |
Freak Poster Join Date: Apr 2012 Location: gsm
Member: 1750690 Status: Offline Thanks Meter: 70 | samsung sm-a310no have a bug not read cert.. here is log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Read CERT Selected model: SM-A310N0 Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-A310N0 Android version: 5.1.1 Product code: Phone version: A310N0KOU1APB6 PDA version: A310N0KOU1APC2 CSC version: A310N0OKS1APC2 CSC country code: KOREA CSC sales code: KOO HW version: A310N0.02 Phone SN: RF1D45EJGGR Modem board: SHANNON310 RF cal date: 20160312 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: B0 97 94 A0 7F 1E 03 CB 12 C7 2C 74 45 78 50 0E Reading NV data... OK Checking NV data... OK Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.26.9 please solve thisproblem |
10-14-2016, 12:44 | #596 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | Searching Samsung modem... detected COM244 Reading phone info... OK Model: SM-G935F AP version: G935FXXU1APAW CSC version: G935Fxxx1APB1 CP version: G935FXXU1APB2 Product code: SM-G935FZKAxxx Phone SN: R58Hxxxxxxx Unique number: AD09160358168EF38E Reading IMEI... OK IMEI: 35355608xxxxxxx (SIGN: OK) Reseting MSL... error (1) |
10-16-2016, 16:53 | #598 (permalink) | |
Junior Member Join Date: Mar 2012
Member: 1730805 Status: Offline Thanks Meter: 2 | Not supported phone Quote:
l try downgrade sboot .bin or modem.bin to 5.1.1 but couldnt get result ..please help me | |
10-16-2016, 18:18 | #600 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
B.R | |
