02-02-2017, 18:44 | #692 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2530835 Status: Offline Thanks Meter: 1 | got NV data error 1 58 when reading unlock code ] Operation: Read Codes [ 2/2/2017 12:31:00 PM ] Selected model: SM-G928W8 [ 2/2/2017 12:31:00 PM ] Software version: 27.7 [ 2/2/2017 12:31:00 PM ] [ 2/2/2017 12:31:00 PM ] Searching Samsung modem... detected COM110 [ 2/2/2017 12:31:00 PM ] Reading phone info... Ok [ 2/2/2017 12:31:00 PM ] Model: SM-G928W8 [ 2/2/2017 12:31:00 PM ] AP version: G928W8VLU4BPK4 [ 2/2/2017 12:31:00 PM ] CSC version: G928W8OYA4BPK4 [ 2/2/2017 12:31:00 PM ] CP version: G928W8VLU4BPK4 [ 2/2/2017 12:31:00 PM ] Product code: SM-G928WZKAGLW [ 2/2/2017 12:31:00 PM ] Phone SN: R58G90SA1GD [ 2/2/2017 12:31:00 PM ] Unique number: 0715F7F045C61105 [ 2/2/2017 12:31:00 PM ] Reading IMEI... Ok [ 2/2/2017 12:31:00 PM ] IMEI: 3525******0 (SIGN: OK) [ 2/2/2017 12:31:00 PM ] Checking hash file... Ok [ 2/2/2017 12:31:00 PM ] Reading data from phone... Ok [ 2/2/2017 12:31:00 PM ] Modem board: SHANNON333 [ 2/2/2017 12:31:00 PM ] HWID: 4* ** 11 3* *7 0* 00 00 00 00 00 00 00 00 00 00 [ 2/2/2017 12:31:00 PM ] Reading NV data... error (1 58) [ 2/2/2017 12:31:00 PM ] getting error reading code on a S6 edge+ G928w8 |
02-03-2017, 04:10 | #694 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2430694 Status: Offline Thanks Meter: 1 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G930F Software version: 27.7 File analysis... Ok Total file size: 0x108A85910 (4234 Mb) Searching USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G930F" "Sending system.img error" - Пошук Google Done with Samsung Tool PRO v.27.7 |
02-03-2017, 09:47 | #695 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2105491 Status: Offline Sonork: 1614736 Thanks Meter: 16 | IMEI Repair working fine but Patch Network is not working at all posted so many times but Z3X team is sleeping somewhere Samsung J5 Prime model : G570f OS : Android OS, v6.0.1 (Marshmallow) Chipset : Exynos 7570 Quad CPU : Quad-core 1.4 GHz Cortex-A53 |
02-05-2017, 13:02 | #696 (permalink) |
02-05-2017, 13:03 | #697 (permalink) |
Member: 2105491 Status: Offline Sonork: 1614736 Thanks Meter: 16 | z3x support is sleeping i think still waiting for samsung g570f network repair if you guys are not sure about the update that it will gonna work for sure then why you launch that like you launched g570f imei repair and network repair but network repair is not working sooooooooooo please help us out |
02-05-2017, 13:04 | #698 (permalink) |
Member: 2105491 Status: Offline Sonork: 1614736 Thanks Meter: 16 | G570f network repair problem IMEI Repair working fine but Patch Network is not working at all posted so many times but Z3X team is sleeping somewhere Samsung J5 Prime model : G570f OS : Android OS, v6.0.1 (Marshmallow) Chipset : Exynos 7570 Quad CPU : Quad-core 1.4 GHz Cortex-A53 |
03-05-2017, 00:43 | #703 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2381269 Status: Offline Thanks Meter: 0 | sgh-a997 UNLOCK INSTRUCTIONS: Micro-UART cable only: 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect phone and press power button. Operation: Read Codes Selected model: SGH-A997 Selected port: COM47 USB Serial Port Software version: 27.7 Connect phone and press power button Timeout Done with Samsung Tool PRO v.27. what i have to do |
