Old 03-10-2018, 20:53   #946 (permalink)
Member: 2506474
Thanks Meter: 20
j327 rev2 unlock by diag port not supported
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever ('Diag' algo):
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever ('Upload' algo):
Knox warranty does not matter.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-J327A
Software version: 30.9
Checking Login and Password... OK
Ballance: 5 crd.
You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM498
Reading phone info... OK
Model: SM-J327A
AP version: J327AUCS2ARA1
CSC version: J327AATT2ARA1
CP version: J327AUCS2ARA1
Product code: ATT
Phone SN: R28JC0QZ9CH
Unique number: CQ300443EE4F4B4
Searching Samsung diag port... detected COM497
CP build: Jan 9 2018 12:16:59
Reading data from phone... error (1)
Searching server... OK
Checking available files... not found compatible file
Try downgrade modem if possible
Done with Samsung Tool PRO v.30.9
Old 03-13-2018, 03:05   #947 (permalink)
Member: 2298273
Thanks Meter: 5
z3x 30.9
not work patch certificate in android 7 binary 3 of j710mn
luckily I was cautious when choosing the binary 3 and not 4
Old 03-15-2018, 09:05   #948 (permalink)
Member: 2821242
Sonork: wws330
Software version: 30.8
Reading phone info...OK
Model: SM-N935F
AP version: N935FXXS2ARA1
CSC version: N935FOLB1AQI5
CP version: N935FXXU2ARA1
CP build: Jan 3 2018 14:03:03
Product code: XME
Reading data from phone...error (1)
Old 03-16-2018, 06:47   #949 (permalink)
Member: 118601
Thanks Meter: 188
LG G6 H873 FRP Reset Failed
Old 03-19-2018, 09:01   #950 (permalink)
Member: 2791545
Thanks Meter: 4
g930xxu2drb6 dm-verity error...
can't repair drk with z3x
can't donwgrade cos new bootloader v2
Any help will be appreciated
Old 03-19-2018, 10:50   #951 (permalink)
Member: 2791545
Thanks Meter: 4
quick temp solution flashed custom rom for now
The Following User Says Thank You to sa_le For This Useful Post:
Old 03-24-2018, 10:53   #952 (permalink)
ishtiyaque_24's Avatar
Member: 1409652
Sonork: 100.1670588
Thanks Meter: 64
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... OK
Model: SM-G935F
Android version: 7.0
Product code: SM-G935FZKUINS
Phone version: G935FXXU2DRAG
PDA version: G935FXXU2DRAG
CSC version: G935FODD2DRAG
CSC country code: India
CSC sales code: INS
HW version: MP 0.801
Phone SN: RF8H31RC88Y
Chip name: EXYNOS8890
Modem board: SHANNON335
Security patch: 2018-01-01
RF cal date: 20160511
IMEI: 357327070336843
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... error (1 19)
Start... OK
Reading data from phone... error (0)
Done with Samsung Tool PRO v.31.0
MR BLANG pls solved my prob sm-g935fd binarry 2 not downgrade how to network repaire
Old 03-24-2018, 13:22   #953 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
issue in setup for z3x pro 31 version
microsoft essentrial security not allow to open after install. its detected as malware/thread/virus/
please check from your side.
thanks.
Old 03-24-2018, 13:23   #954 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
I have teseted three phone, same issue for Phone version: G955USQU2CRB9, version 8.0
Operation: Unlock
Selected model: SM-G955U
Software version: 31.0
Ballance: 55 crd.
You have 55 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G955U
Android version: 8.0.0
Product code: SM-G955UZKATMB
PDA version: G955USQU2CRB9
CSC version: G955UOYN2CRB9
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J5266LRP
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-02-01
RF cal date: 2017.05.18
IMEI: 355980083112775
Waiting for device to become ready... OK
Start... OK
Reading data from phone... error (3.)
Old 03-26-2018, 18:20   #955 (permalink)
Member: 2534813
Thanks Meter: 5
please add support new system of archives samsung 8.0 .lz4
Old 03-27-2018, 06:34   #956 (permalink)
Member: 1752476
Sonork: 1615329
Thanks Meter: 14
j701f cost credit butt no code
3/26/2018 2:53:00 PM ] Operation: Read Codes via Server
[ 3/26/2018 2:53:00 PM ] Selected model: SM-J701F
[ 3/26/2018 2:53:00 PM ] Software version: 31.0
[ 3/26/2018 2:53:00 PM ] Checking Login and Password... OK
[ 3/26/2018 2:53:00 PM ] Ballance: 50 crd.
[ 3/26/2018 2:53:00 PM ] You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes
[ 3/26/2018 2:53:00 PM ] Searching Samsung modem... detected COM184
[ 3/26/2018 2:53:00 PM ] Reading phone info... OK
[ 3/26/2018 2:53:00 PM ] Model: SM-J701F
[ 3/26/2018 2:53:00 PM ] AP version: J701FXXU3ARA4
[ 3/26/2018 2:53:00 PM ] CSC version: J701FOJV3ARA4
[ 3/26/2018 2:53:00 PM ] CP version: J701FXXU3ARA3
[ 3/26/2018 2:53:00 PM ] Product code: XSG
[ 3/26/2018 2:53:00 PM ] Phone SN: RZ8K12ABPXW
[ 3/26/2018 2:53:00 PM ] Unique number: CAJ0027B4C03EC4
[ 3/26/2018 2:53:00 PM ] Searching Samsung diag port... detected COM183
[ 3/26/2018 2:53:00 PM ] CP build: Jan 11 2018 19:02:19
[ 3/26/2018 2:53:00 PM ] Reading data from phone... error (1)
[ 3/26/2018 2:53:00 PM ] Searching server... OK
[ 3/26/2018 2:53:00 PM ] Checking available files... OK
[ 3/26/2018 2:53:00 PM ] Available CP file for downgrade, try download and flash? Continue? Yes
[ 3/26/2018 2:53:00 PM ] Downloading file... OK
[ 3/26/2018 2:56:00 PM ] Checking local file... OK
[ 3/26/2018 2:56:00 PM ] Switching to flash mode... OK
[ 3/26/2018 2:56:00 PM ] Searching USB Flash interface... COM53 detected
[ 3/26/2018 2:56:00 PM ] Setup connection... OK
[ 3/26/2018 2:56:00 PM ] Reading data from phone... OK
[ 3/26/2018 2:56:00 PM ] Sending data to phone... OK
[ 3/26/2018 2:56:00 PM ] Searching Samsung modem... detected COM184
[ 3/26/2018 2:57:00 PM ] Reading phone info... OK
[ 3/26/2018 2:57:00 PM ] Model: SM-J701F
[ 3/26/2018 2:57:00 PM ] AP version: J701FXXU3ARA4
[ 3/26/2018 2:57:00 PM ] CSC version: J701FOJV3ARA4
[ 3/26/2018 2:57:00 PM ] CP version: J701FXXU3ARA1
[ 3/26/2018 2:57:00 PM ] Product code: XSG
[ 3/26/2018 2:57:00 PM ] Phone SN: RZ8K12ABPXW
[ 3/26/2018 2:57:00 PM ] Unique number: CAJ0027B4C03EC4
[ 3/26/2018 2:57:00 PM ] Searching Samsung diag port... detected COM183
[ 3/26/2018 2:57:00 PM ] CP build: Jan 3 2018 14:19:14
[ 3/26/2018 2:57:00 PM ] Reading data from phone... OK
[ 3/26/2018 2:58:00 PM ] Calculating... OK
[ 3/26/2018 2:58:00 PM ] Searching server...
[ 3/26/2018 3:13:00 PM ] Operation: Read Codes via Server
[ 3/26/2018 3:13:00 PM ] Selected model: SM-J701F
[ 3/26/2018 3:13:00 PM ] Software version: 31.0
[ 3/26/2018 3:13:00 PM ] Checking Login and Password... OK
[ 3/26/2018 3:13:00 PM ] Ballance: 45 crd.
[ 3/26/2018 3:13:00 PM ] You have 45 credit(s) left. This operation takes 5 credits.Continue? No
Old 03-27-2018, 07:44   #957 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
t-mobile device unlock app s8 new security not supproted
Operation: Unlock
Selected model: SM-G950U
Ballance: 150 crd.
You have 150 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G950U
Product code: SM-G950UZKATMB
Phone version: G950USQU2CRB9
PDA version: G950USQU2CRB9
CSC version: G950UOYN2CRB9
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J41F644L
Chip name: MSM8998
RF cal date: 2017.04.13
IMEI: 355987081582362
Start... OK
Old 03-27-2018, 14:00   #958 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
NOT SUPPORTED Product code: SM-G955UZKATMB, PDA version: G955USQU2CRB9 - T-MOBILE DEV
LATEST FIRMWARE 8.0
NOT SUPPORTED - NOT SUPPORTED Product code: SM-G955UZKATMB, PDA version: G955USQU2CRB9 - T-MOBILE DEVICE UNLOCK APP
Operation: Unlock
Ballance: 125 crd.
You have 125 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J42D1YLF
Chip name: MSM8998
RF cal date: 2017.04.19
IMEI: 355980081933644
Start... OK
Old 03-28-2018, 08:34   #959 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
again new phone - s8 not supported, new security and firmware
S8 T-mobile device unlock app, not supported for unlock
Operation: Unlock
Ballance: 115 crd.
You have 115 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G950U
Product code: SM2G950UZKATMB
CSC sales code: TMB
HW version: REV1.0
Phone SN: RF8JA14A2HP
Chip name: MSM8998
RF cal date: 2017.10.09
IMEI: 353111090822071
Rebooting phone... OK
Start... OK
Old 03-29-2018, 07:36   #960 (permalink)
Member: 2190317
Thanks Meter: 8
t mobile app lock locked back after 30 days
sir after unlocking samsung j327t it locked back after 30days
customer called after 30days to inform me that phone locked back
he has not been in town came back last weekend with phone and i checked
it its true. the log i saved is still in my system. i can show video proof if
required . my log in id zsc_1BkdXo8p
Operation: Unlock
Selected model: SM-J327T
Software version: 30.5
Checking Login and Password... could not connect to server
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-J327T
Product code: SM2J327TZKATMB
Phone version: J327TUVU1AQCB
PDA version: J327TUVU1AQCB
CSC version: J327TTMB1AQCB
CSC sales code: TMB
HW version: REV0.1
Phone SN: R28J52S910V
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-03-01
RF cal date: 20170523
IMEI: 355xxxxxxxxx515
Searching Samsung diag port... detected COM239
CP version: J327TUVU1AQCB
CP build: Mar 23 2017 16:50:58
Calculating... OK
Waiting for server answer... OK
Start... OK
Unlock done
Done with Samsung Tool PRO v.30.5
Page generated in 0.19862 seconds with 8 queries
