Old 11-11-2018, 18:07   #1111 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,092
Sorry, guys Seems like it was my fault... I was told new versions of Samsung Tool (with new unlocking algo) req more powerfull PC. My old laptop with 2gb RAM on XP does not work properly with new software. My second PC ( Win 7 x64, i7 3.2 Ghz, 6Gb RAM) read codes without any errors.
Old 11-14-2018, 01:38   #1112 (permalink)
Member: 906256
Thanks Meter: 39
hi.plz support write patch u3 android8 if possible.tnx for support
Old 11-14-2018, 11:42   #1113 (permalink)
phudzgsm2010's Avatar
Member: 1351276
Thanks Meter: 46
Putang inag set up yan asan na yan
Old 11-15-2018, 07:43   #1114 (permalink)
Member: 131470
Thanks Meter: 9
Frp n9208dx not working
Old 11-16-2018, 06:44   #1115 (permalink)
Crazy Poster
Member: 2439345
Thanks Meter: 2
Selected model: SM-G965U1
Software version: 34.3
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G965U1
Android version: 8.0.0
PDA version: G965U1UEU3ARJ2
CSC version: G965U1OYM3ARJ2
Phone version: G965U1UEU3ARJ2
Product code: SM-G965UZBAATT
CSC country code: USA
CSC sales code: ATT
Phone SN: R38K206MWMT
IMEI: 354641090226229
HW version: REV1.1
RF cal date: 2018.02.18
Chip name: SDM845
Modem board: SDM845
Security patch: 2018-10-01
Boot Warranty bit: 0
SIM State: NETWORK_LOCKED
Searching Samsung diag port... not found
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM13 detected
Calculating...
Exception: Invalid pointer operation
Done with Samsung Tool PRO v.34.3
Old 11-16-2018, 06:44   #1116 (permalink)
Crazy Poster
Member: 2439345
Thanks Meter: 2
please help team need support
Old 11-18-2018, 00:11   #1117 (permalink)
err0r_'s Avatar
Member: 2787425
Thanks Meter: 25
Ballance: 20 crd.
Model: SM-G965U1
CSC sales code: ATT
HW version: REV1.1
Chip name: SDM845
Modem board: SDM845
Start... OK
Calculating...
Did you try to activate the modem port, i think its *#0808#
Try selecting G965U model
Or install the regular G965U Att rom and try again, or try to do a factory reset, wipe cache and re try
Old 11-18-2018, 06:52   #1118 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Unlock
Selected model: SM-G530T
Ballance: 19 crd.
You have 19 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G530T
Android version: 5.1.1
PDA version: G530TUVU1AOF8
CSC version: G530TTMB1AOF8
Phone version: G530TUVU1AOF8
Product code: SM2G530TZAATMB
CSC sales code: TMB
Phone SN: R28H21GXAWF
IMEI: 359128069952600
HW version: REV0.1
RF cal date: 2016.02.16
Chip name: MSM8916
Modem board: MSM8916
Boot Warranty bit: 1
SIM State: ABSENT
Checking Super user right... true
Start... OK
Rebooting to upload... OK
Searching Ramdump interface... COM5 detected
Calculating... OK
Searching server... error
could not connect to server
Old 11-21-2018, 12:32   #1119 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 385
J730g b4 on last version with root not nunlock with version 33.5 work perfect
Model: SM-J730G
Android version: 7.0
PDA version: J730GUBU4ARF1
CSC version: J730GZTO4ARF1
Phone version: J730GDXU4ARF1
Product code: SM-J730GZKGZTO
CSC country code: Brazil
CSC sales code: ZTO
Phone SN: 00000000000
IMEI: 356202095853943
HW version: MP 0.500
RF cal date: 20180429
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2018-06-01
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: 4C 5B 49 CA FD 48 C1 6B B1 A0 5E 94 AF 3B 74 5C
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.33.5
I NOTICED ALWAYS WE TRY IN ANY OPERTION I CAN NOT MENSION ALL WHEN I FOUND ONE IWILL REPORT ALWAYS DOWNGRADE THE MOUDLE TO DO SOMTHING
PLZ FIX THIS THX IN ADVANCE
MY BEST SAMSUNG BOX EVER
Old 11-21-2018, 13:17   #1120 (permalink)
ufs-4's Avatar
Member: 346934
Sonork: 100.1575675
Thanks Meter: 53
hi
how are you
no recived any unlock code
this log
help me for get unlock code
[ 20/11/2018 09:01:37 م ] Checking Login and Password... OK
[ 20/11/2018 09:01:39 م ] Ballance: 20 crd.
[ 20/11/2018 09:01:42 م ] You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes
[ 20/11/2018 09:01:45 م ] Waiting ADB device... OK
[ 20/11/2018 09:01:48 م ] Reading phone info...
[ 20/11/2018 09:01:48 م ] Model: SM-G950U
[ 20/11/2018 09:01:48 م ] Android version: 7.0
[ 20/11/2018 09:01:49 م ] PDA version: G950USQS1AQF7
[ 20/11/2018 09:01:49 م ] CSC version: G950UOYN1AQF7
[ 20/11/2018 09:01:50 م ] Phone version: G950USQS1AQF7
[ 20/11/2018 09:01:50 م ] Product code: SM-G950UZVAATT
[ 20/11/2018 09:01:50 م ] CSC country code: USA
[ 20/11/2018 09:01:51 م ] CSC sales code: ATT
[ 20/11/2018 09:01:51 م ] Phone SN: R38J40500SW
[ 20/11/2018 09:01:51 م ] IMEI: 357724080505815
[ 20/11/2018 09:01:52 م ] HW version: REV1.0
[ 20/11/2018 09:01:52 م ] RF cal date: 2017.04.06
[ 20/11/2018 09:01:53 م ] Chip name: MSM8998
[ 20/11/2018 09:01:53 م ] Modem board: MSM8998
[ 20/11/2018 09:01:53 م ] Security patch: 2017-06-01
[ 20/11/2018 09:01:54 م ] Boot Warranty bit: 0
[ 20/11/2018 09:01:54 م ] SIM State: ABSENT
[ 20/11/2018 09:01:56 م ] Rebooting phone... OK
[ 20/11/2018 09:02:02 م ] Waiting ADB device... OK
[ 20/11/2018 09:02:18 م ] Waiting for device to become ready... OK
[ 20/11/2018 09:02:28 م ] Initialization zTool... OK
[ 20/11/2018 09:02:30 م ] Running zTool, please wait...
[ 20/11/2018 09:02:30 م ] Start... OK
[ 20/11/2018 09:02:37 م ] Initialization... OK
[ 20/11/2018 09:02:39 م ] Generate and check client proof... OK
[ 20/11/2018 09:02:39 م ] Verify proof by client... OK
[ 20/11/2018 09:02:39 م ] Reading data from phone... OK
[ 20/11/2018 09:02:47 م ] Searching Ramdump interface... COM6 detected
[ 20/11/2018 09:04:03 م ] Reading data from phone... OK
[ 20/11/2018 09:04:10 م ] Calculating... OK
[ 20/11/2018 09:04:11 م ] Searching server... OK
[ 20/11/2018 09:04:28 م ] Waiting for server answer...
Report Post
Old 11-21-2018, 21:52   #1121 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Thanks Meter: 46
http://forum.gsmhosting.com/vbb/f453...rsion-2516242/
Old 11-25-2018, 11:32   #1122 (permalink)
Member: 483673
Is there anyway to flash a new IMEI number to U3 binary?
Old 12-05-2018, 20:58   #1123 (permalink)
Member: 1815016
Thanks Meter: 58
G960u g965u bug
Very common issue with CTT and ATT, for S9 and S9+. Happens to 90% of devices - less than 10% success. What happens is "Reading data from phone" step never complete. Phone continue to modem upload mode, but tool never advances to next step. So phone stays stuck in modem upload mode forever. Have tried with diag mode and without, uninstall/reinstall drivers, many troubleshooting steps. No solution.
Important: problem seems to exist only on Windows 10. If procedure is repeated on Windows 7 computer, everything works fine.
[ 12/5/2018 2:39:02 PM ] Operation: Read Codes via Server
[ 12/5/2018 2:39:02 PM ] Selected model: SM-G965U
[ 12/5/2018 2:39:02 PM ] Software version: 34.3
[ 12/5/2018 2:39:02 PM ] Checking Login and Password... OK
[ 12/5/2018 2:39:03 PM ] Ballance: 50 crd.
[ 12/5/2018 2:39:05 PM ] You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes
[ 12/5/2018 2:39:07 PM ] Waiting ADB device... OK
[ 12/5/2018 2:39:08 PM ] Reading phone info...
[ 12/5/2018 2:39:08 PM ] Model: SM-G965U
[ 12/5/2018 2:39:08 PM ] Android version: 8.0.0
[ 12/5/2018 2:39:08 PM ] PDA version: G965USQU3BRJ5
[ 12/5/2018 2:39:08 PM ] CSC version: G965UOYN3BRJ5
[ 12/5/2018 2:39:08 PM ] Phone version: G965USQU3ARG2
[ 12/5/2018 2:39:08 PM ] Product code: SM-G965UZPACCT
[ 12/5/2018 2:39:08 PM ] CSC country code: USA
[ 12/5/2018 2:39:08 PM ] CSC sales code: CCT
[ 12/5/2018 2:39:08 PM ] Phone SN: R28K428
[ 12/5/2018 2:39:08 PM ] IMEI: 3535150
[ 12/5/2018 2:39:08 PM ] HW version: REV1.1
[ 12/5/2018 2:39:08 PM ] RF cal date: 2018.04.20
[ 12/5/2018 2:39:08 PM ] Chip name: SDM845
[ 12/5/2018 2:39:08 PM ] Modem board: SDM845
[ 12/5/2018 2:39:08 PM ] Security patch: 2018-10-01
[ 12/5/2018 2:39:09 PM ] Boot Warranty bit: 0
[ 12/5/2018 2:39:09 PM ] SIM State: NETWORK_LOCKED
[ 12/5/2018 2:39:11 PM ] Searching Samsung diag port... not found
[ 12/5/2018 2:39:12 PM ] Waiting for device to become ready... OK
[ 12/5/2018 2:39:14 PM ] Initialization zTool... OK
[ 12/5/2018 2:39:15 PM ] Running zTool, please wait...
[ 12/5/2018 2:39:15 PM ] Start... OK
[ 12/5/2018 2:39:18 PM ] Initialization... OK
[ 12/5/2018 2:39:19 PM ] Generate and check client proof... OK
[ 12/5/2018 2:39:19 PM ] Verify proof by client... OK
[ 12/5/2018 2:39:19 PM ] Reading data from phone...
Old 12-07-2018, 04:59   #1124 (permalink)
Member: 2881882
samsung note8 n950f error1
I have bought Samsung Z3x dongle and I have tried to unlock my phone from network lock. It goes ok but stops after reading imei, stops on reading SN and says error1. I have sent a message to seller on ebay and he said to contact you guys on this forum. Help please.
Old 12-07-2018, 08:41   #1125 (permalink)
Member: 2712640
Thanks Meter: 6
please add support for andrid 8.x like i av j701f with android 8.x i rooted it succesfully but am failing to patch certificate only emercecy calls only
n the phone is binary 6 no way to downgrade to 7.0
Page generated in 0.42309 seconds with 8 queries
