05-20-2015, 07:28 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: worldwide
Member: 1948841 Status: Offline Sonork: yocomic Thanks Meter: 45 | help flashing always get an error 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SGH-I777 Software version: 20.5 File analysis... OK Total file size: 0x22197B40 (545 Mb) Searching USB Flash Interface... detected COM43 Setup connection... OK Reading PIT from phone... OK Sending boot.bin... error timeout Done with Samsung Tool v.20.5 progran run as administrador and compatible whit xp sp3 what is wrong/?? |
