10-26-2016, 11:26 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: puerto rico
Member: 2282504 Status: Offline Thanks Meter: 50 | help flashing error lg k530f Modo: Emergencia \par modelo K530F \par Transcurrido 2 segundos --> (v9.27) \par \par Telefono en modo DESCARGA \par Comenzando a Parpadear \par Abriendo archivo KDZ: C:\\Users\\TORRES PC\\Downloads\\K530F10b_00_0707 (2).kdz \par Modelo: LG-K530 \par Versi\f1\'f3n de Software: K53010b \par \f0 Tiempo de construcci\f1\'f3n: 0000-00-00 00:00:00 \par \f0 Total Files : 72 \par Model name: LG-K530F \par Software verion: K53010b \par Android verion: 6.0.1 \par IMEI: 357883070450273 \par Laf flash error: incompatible partition table [start] 01D19800:01D5BFDE, grow \par Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. \par Start direct download mode \par Write "PrimaryGPT" partition #1 of 72 \par Write "modem" partition #2 of 72 \par Write "sbl1" partition #3 of 72 \par Write "sbl1bak" partition #4 of 72 \par Write "rpm" partition #5 of 72 \par Write "rpmbak" partition #6 of 72 \par Write "tz" partition #7 of 72 \par Write "tzbak" partition #8 of 72 \par Write "dsp" partition #9 of 72 \par Write "sec" partition #10 of 72 \par Write "aboot" partition #11 of 72 \par Write "abootbak" partition #12 of 72 \par Write "boot" partition #13 of 72 \par Write "laf" partition #14 of 72 \par Write "recovery" partition #15 of 72 \par Write "recoverybak" partition #16 of 72 \par Write "factory" partition #17 of 72 \par Write "raw_resources" partition #18 of 72 \par Write "raw_resourcesbak" partition #19 of 72 \par Write "persist" partition #20 of 72 \par Write "apdp" partition #21 of 72 \par Write "msadp" partition #22 of 72 \par Write "devcfg" partition #23 of 72 \par Write "devcfgbak" partition #24 of 72 \par Write "lksecapp" partition #25 of 72 \par Write "lksecappbak" partition #26 of 72 \par Write "cmnlib" partition #27 of 72 \par Write "cmnlibbak" partition #28 of 72 \par Write "cmnlib64" partition #29 of 72 \par Write "cmnlib64bak" partition #30 of 72 \par Write "keymaster" partition #31 of 72 \par Write "keymasterbak" partition #32 of 72 \par Write "cust" partition #33 of 72 \par Write "system" partition #34 of 72 \par Write "system" partition #35 of 72 \par Write "system" partition #36 of 72 \par Write "system" partition #37 of 72 \par Write "system" partition #38 of 72 \par Write "system" partition #39 of 72 \par Write "system" partition #40 of 72 \par Write "system" partition #41 of 72 \par Write "system" partition #42 of 72 \par Write "system" partition #43 of 72 \par Write "system" partition #44 of 72 \par Write "system" partition #45 of 72 \par Write "system" partition #46 of 72 \par Write "system" partition #47 of 72 \par Write "system" partition #48 of 72 \par Write "system" partition #49 of 72 \par Write "system" partition #50 of 72 \par Write "system" partition #51 of 72 \par Write "system" partition #52 of 72 \par Write "system" partition #53 of 72 \par Write "system" partition #54 of 72 \par Write "system" partition #55 of 72 \par Write "system" partition #56 of 72 \par Write "system" partition #57 of 72 \par Write "system" partition #58 of 72 \par Write "system" partition #59 of 72 \par Write "system" partition #60 of 72 \par Write "system" partition #61 of 72 \par Write "system" partition #62 of 72 \par Write "system" partition #63 of 72 \par Write "system" partition #64 of 72 \par Write "system" partition #65 of 72 \par Write "system" partition #66 of 72 \par Write "system" partition #67 of 72 \par Write "OP" partition #68 of 72 \par Write "OP" partition #69 of 72 \par Write "OP" partition #70 of 72 \par Write "OP" partition #71 of 72 \par Write "BackupGPT" partition #72 of 72 \par Erase "rct" partition \par Hecho. \par Transcurrido 534 segundos --> (v9.27) |
10-26-2016, 19:54 | #2 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | http://amazhack.********.com/2016/04...e-nt-code.html Or you can fix this from service menu - I not remember item name in menu. -- |
10-27-2016, 13:29 | #3 (permalink) | |
Member: 2282504 Status: Offline Thanks Meter: 50 | Quote:
10-27-2016, 22:18 | #5 (permalink) | |
Member: 2282504 Status: Offline Thanks Meter: 50 | Quote: | |
10-27-2016, 23:07 | #6 (permalink) |
Member: 2282504 Status: Offline Thanks Meter: 50 | steps to follow if you leave this annoying message (current version is not available for user. can not find matched cust for nt-code mcc / mnc / subset) after flashing filmware at least I pass me with a lg stylus 2 plus. (1). They enter the hidden menu. (2) then the hidden menu, go to (svc menu) and look where it says (version info) then version info search (Original sw version. There are going to realize where this software belongs. Example (LGK530FAT-00 -V10b-GLOBAL-SCA-JUL-07-2016) if you notice before the date this initial SCA where it belongs or the software may also see initials at the beginning where it says sw version info but in this case, I did not appear me. ok. now let the most important. once you know initials do not we go back to the main menu svc. below'll find where it says (CRCWIZARD Test) within crc wizard in part above 2 options will appear. (CRC Values) and (Auto MID), you choose auto mid and see that the menu will change and will give you more options. in the latest below where it says MID Setting tells you NT Code, has 2 options with arrows pointing down. 1st choose which tells you initials and give click and you will come out a listing of the operators in different countries. there you'll find the initials of your sofware in this case was mine SCA. once choose yours, next to where (NT Code), there is a picture and see that will appose some example "1",FFF,FFF,FFFFFFFF,FFFFFFFF,32"in this case this is the one that belonged to me . you're going to copy exactly like this or give him a copy paste. one you see what has left of the screen and go to SVC and then to Version info again and buscamo the option that says NT Code. we click and paste what copied. once to copy you give accept and will say (NTCODE WRITE OK). if you get NTCODE ERROR, return to the procedure that the safest thing they'll stay. if everything went all right, reboot and you will see everything went well. sorry my english Last edited by ltindi32; 10-27-2016 at 23:14. |
