08-18-2014, 17:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 432765 Status: Offline Thanks Meter: 65 | help in i9305 phone rooted usb debugging on this logo for unlock Selected model: I9305 Selected port: COM7 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179599 Reading security... error access denied Done with Samsung Tool v.18.0 Done with Samsung Tool v.18.0 |
08-18-2014, 18:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,078 | 1ST Hard Reset I9305... micro-uart cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for UART and PDA for USB options. 3. Press "Quallcomm USB settings" and select "DM+MODEM+ADB". 4. Connect the phone to UART port. 5. Choose correct COM port in port settings 6. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for USB and PDA for UART options. 3. Press "Quallcomm USB settings" and select "DM+MODEM+ADB". 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. Tara Mobile Service |
08-18-2014, 18:55 | #3 (permalink) | |
Member: 432765 Status: Offline Thanks Meter: 65 | Quote:
i am doing this steps but still same mayb i have problem in root need steps to root phone i9305 4g version 4.3 | |
08-18-2014, 19:41 | #6 (permalink) | |
1. Download Odin from this post. 2. Download I9305_CWM_Recovery.tar.md5 3. Unzip Odin to your desktop. 4. Copy the I9305_CWM_Recovery.tar.md5 to the same directory. 5. Boot your SGS in to download mode. (Power off and then press and hold the power + volume down + home buttons at the same time) 6. Connect your phone to your PC using the cable that came with it. 7. If Kies is running on your pc shut it down. 8. Open the Odin application. (Make sure your phone is detected, there will be a yellow square in the top left corner.) 9. Choose PDA button and select the I9305_CWM_Recovery.tar.md5. 10. Press start and wait. Your phone will be flashed and reboot when it is finished. (After Odin finish let the device reboot to android at least one time before applying I9305_CWM_Recovery.tar.md5.) 11. When the phone reboot, power it off again. 12. Put the phone in recovery mode. (Hold down power, volume up and home when the device is turned off and unplugged.) 13. After that you can flash the Root_SuperSU.1.02-Busybox.1.21.0.zip to be ROOTED to any firmware and make a backup and restore of your firmware, also you can now flash any custom rom / kernel made for GT-I9305. | |
08-18-2014, 19:57 | #7 (permalink) |
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,078 | I think New security (error access denied) no any idea......THANKS Try By Downgrading The Android 4.1.1 (At your own risk) Tara Mobile Service |
