01-08-2013, 13:38 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: nigeria
Member: 1331008 Status: Offline Thanks Meter: 11 | help me with e2222 chat 222 Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... Aborted by user Elapsed time: 25 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- --------------------------- 1/8/2013 4:14:22 AM ----------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... Aborted by user Elapsed time: 25 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- --------------------------- 1/8/2013 4:15:00 AM ----------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... Aborted by user Elapsed time: 25 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM8 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
01-09-2013, 04:30 | #5 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | its driver problem.. install driver from c/program/z3x/samsung /all/ usb driver then try again.... |
The Following User Says Thank You to mobi_soft For This Useful Post: |
01-09-2013, 04:33 | #6 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Cuba
Member: 1718709 Status: Offline Thanks Meter: 10 | here you have bro: Firmware Update Process: - First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed - Power on the phone and connect USB cable to it and to PC to let Windows install its drivers. - Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers. - Run the E2222 Ch@t Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe - Click SET MODEL button and select: E2222_TEXTO_Setting_v00.mdl - For Application Binary File select: E2222xx.ptt - For Tfs file select: E2222xxxxx.tfs - For CSC file select: E2222Oxxxxx.csc - Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers. - Disconnect the phone after DFU drivers installed. - Click START button and reconnect USB cable to phone while pressing Q + A keys. - The program will detect it and start the Update Process so wait till all is DONE. - Disconnect the phone and turn it on then do Full reset: *2767*3855# i take this from ASANSAM Dongle i jope this help you br. |
The Following User Says Thank You to MovilesTomasito For This Useful Post: |
01-09-2013, 04:38 | #7 (permalink) |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | or try this one. use rj45 micro uart cable select right com port then flash, and make power on the phone. if you are using usb you need to hold this key. / Q / A / S. then insert usb |
01-09-2014, 15:51 | #8 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1339806 Status: Offline Thanks Meter: 1 | ANY 1 TO HELP SOLVE THIS PROBLEM Selected model: I9300 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4B6A6B2C Searching USB Flash Interface... detected COM35 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_9-1-2014_17-45-54.pit Sending sboot.bin... OK Sending param.bin... OK Sending tz.img... OK Sending sboot.bin... OK Sending param.bin... OK Sending tz.img... OK Sending boot.img... Error Done with Samsung Tool v.16.0 Done with Samsung Tool v.16.0 |
