11-21-2016, 08:25 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | help me j700h frp remove 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J700H Software version: 27.1 File analysis... ok Total file size: 0x28FB6288 (655 Mb) Searching USB Flash interface... COM3 detected Setup connection... ok Reading PIT from phone... ok Sending sboot.bin... ok Sending param.bin... ok Sending cm.bin... ok Sending boot.img... ok Sending recovery.img... ok Sending system.img... ok Sending persdata.img... ok Sending cache.img... ok Sending modem.bin... ok Flashing done (time - 00:00:43) Done with Samsung Tool PRO v.27.1 then after frp bypass all ok but and factory reset done then after update file write done but then after show google id and password how to slove my problem.............. but i face same problem frp remove 100% done other phone z3x |
11-21-2016, 08:57 | #2 (permalink) |
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-J700H Software version: 27.1 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... ok Reading phone info... Model: SM-J700H Android version: 5.1.1 Product code: SM-J700HZDDSER Phone version: J700HXXU2APC1 PDA version: FA51_J700HXXU2APE1 CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R21G92N905A Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20150918 IMEI: Bypass FRP... ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.1 no susses frp how to do |
