05-22-2015, 17:19 | #1 (permalink) |
Crazy Poster Join Date: Apr 2012
Member: 1749975 Status: Offline Thanks Meter: 3 | help me samsung g530fz unlock error Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G530FZ Selected port: COM15 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: xxxxxxxxxxxxxxxxxxx Reading security... new type Bypassing... OK Unlocking... error REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Fill values what you need to repair. 10. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Press 'Wipe EFS/NVM' button. Done with Samsung Tool v.20.5 |
06-11-2015, 15:17 | #2 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1827652 Status: Offline Thanks Meter: 0 | got this : Operation: Unlock Selected model: SM-G530FZ Selected port: COM132 SAMSUNG Mobile USB Serial Port , Software version: 20.0 Reading phone info... Reading IMEI... OK IMEI: 357379068317269 Reading security... error Detected new type of security Bypassing... OK Unlocking... error Done with Samsung Tool v.20.0 |
06-11-2015, 16:45 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | Quote:
use pro ver........... | |
