05-21-2013, 14:58 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: somewhere in world Age: 37
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | help me urgently..i9100 imei repair... Searching Samsung modem... not found Done with Samsung Tool v.13.5 Selected model: I9100 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM96 Reading phone info... Software version: I9100XWLSD/I9100XXLS8/I9100FOPLS4 IMEI: 004999010640000 Done with Samsung Tool v.13.5 Selected model: I9100 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100XXLS8 PDA version: I9100XWLSD CSC version: I9100FOPLS4 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Searching Samsung modem... detected COM96 Waiting while modem will be ready... No answer from phone Done with Samsung Tool v.13.5 Done with Samsung Tool v.13.5 |
05-21-2013, 15:26 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Quote:
use version 12.7 and all will be ok or another older version. SamsungTool_12.7.rar here is 12.7 | |
05-22-2013, 08:05 | #5 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | man look ther http://forum.gsmhosting.com/vbb/9405106-post25.html |
05-22-2013, 12:28 | #6 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | brother SHIJILFONOTLY after dowengrading my handset stuck on samsung galaxy sii gt-i9100..pls help me otherwise coustemer kill me... |
05-22-2013, 13:18 | #8 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | thanks every one....i have solved this 1 ] downgrade handset to v2.3.3 2 ] do imei repair in z3x v 12.7 Count supported models - 319 Android Version: 2.3.3 Model: GT-I9100 Product Code: Not Active Phone Version: I9100XXKDJ PDA Version: I9100XEKE2 CSC Version: I9100OXEKE1 IMEI: 004999010640000 Checking ROOT... FALSE Rooting Phones, Please Wait... OK Checking ROOT... TRUE Reading Data From Phone... OK Writing NV Data To Phone... OK Rebooting Phone... OK Searching Samsung USB Modem... Detected COM5 Bypass MSL... OK Repairing IMEI... OK New IMEI: 3568xxxxxxxxxxx Rebooting... OK Done with Samsung Tool ver 12.7 |
05-22-2013, 19:17 | #10 (permalink) |
Registered User Join Date: May 2007 Location: Canada
Member: 514340 Status: Offline Thanks Meter: 68 | No need any big steps 1) Download samsung firmware for i9100 ..make sure to download the right firmware 2) fllash using Odin 3) Repair IMEI using z3x (use old version mentioned above) Download firmware from here w3ww.**************/firmwares/1/ Download Odin from here Odin 1.83 - Download |
05-23-2013, 11:43 | #12 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | brother add me on yahoo...i will solve your problem...my [email protected] |
05-26-2013, 09:08 | #14 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | complit procedure.... 1] download u1_02_20110310_emmc_EXT4.pit 2] download file I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME 3] download Odin3 v1.85 these all files can be downloaded 4m ufs server. procedure.... 1] open odin 2] check on re-partition,auto reboot,f.reset time 3] select pit file---> u1_02_20110310_emmc_EXT4.pit 4] select pda file---> I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME 5] put handset in download mode (volume down+ home+power key) and connect to pc 6] start flashing... after flashing...handset alive...and use z3x v12.7 to rebuild imei. press thanks if it works 4 you... |
The Following User Says Thank You to sonualok For This Useful Post: |
05-26-2013, 09:22 | #15 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 269 | Hi, After downgrade just put phone in recovery mode (vol up + home + power) and wipe data and cache. But not need to do this mess, select com mode, connect to usb, press repair, when phone reboot connect to the box using c3300k cable, that'all. Repeat, downgrade is needed only for 4.1.2 version. Br Ss |
The Following User Says Thank You to agentot For This Useful Post: |
