Old 05-21-2013, 14:58   #1 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
help me urgently..i9100 imei repair...
Selected port speed: 115200
Searching Samsung modem... not found
Done with Samsung Tool v.13.5
Selected model: I9100
Selected port: COM4 Z3X BOX Serial Port
Searching Samsung modem... detected COM96
Reading phone info...
Software version: I9100XWLSD/I9100XXLS8/I9100FOPLS4
IMEI: 004999010640000
Model: GT-I9100
Android version: 4.1.2
Product code: Not Active
Phone version: I9100XXLS8
PDA version: I9100XWLSD
CSC version: I9100FOPLS4
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Writing data to phone... OK
Rebooting phone... OK
Waiting while modem will be ready...
No answer from phone
Old 05-21-2013, 15:26   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
Model: GT-I9100
IMEI: Unknown
your version of samsung tool.
use version 12.7 and all will be ok or another older version.
SamsungTool_12.7.rar
here is 12.7
Old 05-22-2013, 06:34   #3 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
brother i used v10.7 to 14.4 all version shows this error...
Old 05-22-2013, 07:08   #4 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 1,061
bro downgrade your firmware and do imei repair and post result
Absar_Global
Old 05-22-2013, 08:05   #5 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
man look ther
http://forum.gsmhosting.com/vbb/9405106-post25.html
Old 05-22-2013, 12:28   #6 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
brother SHIJILFONOTLY
after dowengrading my handset stuck on samsung galaxy sii gt-i9100..pls help me otherwise coustemer kill me...
Old 05-22-2013, 12:46   #7 (permalink)
Member: 351924
ok are you using sonork?
contact me i will help you
Old 05-22-2013, 13:18   #8 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
thanks every one....i have solved this
1 ] downgrade handset to v2.3.3
2 ] do imei repair in z3x v 12.7
Count supported models - 319
Android Version: 2.3.3
Model: GT-I9100
Product Code: Not Active
Phone Version: I9100XXKDJ
PDA Version: I9100XEKE2
CSC Version: I9100OXEKE1
Checking ROOT... FALSE
Rooting Phones, Please Wait... OK
Checking ROOT... TRUE
Reading Data From Phone... OK
Writing NV Data To Phone... OK
Rebooting Phone... OK
Searching Samsung USB Modem... Detected COM5
Bypass MSL... OK
Repairing IMEI... OK
New IMEI: 3568xxxxxxxxxxx
Rebooting... OK
Done with Samsung Tool ver 12.7
Old 05-22-2013, 19:04   #9 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
same problem imei repair
need guide to downgrade i9100 4.0.4 to 2.3.3 step by step plz help
Old 05-22-2013, 19:17   #10 (permalink)
Registered User
Member: 514340
Thanks Meter: 68
No need any big steps
1) Download samsung firmware for i9100 ..make sure to download the right firmware
2) fllash using Odin
3) Repair IMEI using z3x (use old version mentioned above)
Download firmware from here
w3ww.**************/firmwares/1/
Download Odin from here
Odin 1.83 - Download
Old 05-22-2013, 20:29   #11 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
Bro wiret flash Odin completed but hang on logo plz help
Old 05-23-2013, 11:43   #12 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
brother add me on yahoo...i will solve your problem...my [email protected]
Old 05-25-2013, 15:49   #13 (permalink)
Member: 194907
Thanks Meter: 114
yes same problem 2.3.3 downgrade phone only logo no power how to solve?
Old 05-26-2013, 09:08   #14 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 505
complit procedure....
1] download u1_02_20110310_emmc_EXT4.pit
2] download file I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME
3] download Odin3 v1.85
these all files can be downloaded 4m ufs server.
procedure....
1] open odin
2] check on re-partition,auto reboot,f.reset time
3] select pit file---> u1_02_20110310_emmc_EXT4.pit
4] select pda file---> I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME
5] put handset in download mode (volume down+ home+power key) and connect to pc
6] start flashing...
after flashing...handset alive...and use z3x v12.7 to rebuild imei.
press thanks if it works 4 you...
The Following User Says Thank You to sonualok For This Useful Post:
Old 05-26-2013, 09:22   #15 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 269
Hi,
After downgrade just put phone in recovery mode (vol up + home + power) and wipe data and cache.
But not need to do this mess, select com mode, connect to usb, press repair, when phone reboot connect to the box using c3300k cable, that'all.
Repeat, downgrade is needed only for 4.1.2 version.
Ss
The Following User Says Thank You to agentot For This Useful Post:
Page generated in 0.23462 seconds with 9 queries
