11-02-2016, 13:00 | #1 (permalink) |
Insane Poster Join Date: Aug 2008 Location: Hungary Age: 41
Member: 830047 Status: Offline Thanks Meter: 6 | Help N910F unlocking errpr (0) Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910F Selected port: COM72 SAMSUNG Mobile USB Serial Port Software version: 27.0 Reading phone info... Reading IMEI... ok IMEI: 356900067039488 Unlocking... error (0) Done with Samsung Tool PRO v.27.0 Please help thx |
11-02-2016, 13:01 | #2 (permalink) |
Member: 830047 Status: Offline Thanks Meter: 6 | a300fu Operation: Unlock Selected model: SM-A300FU Selected port: COM69 SAMSUNG Mobile USB Serial Port Software version: 27.0 Reading phone info... Reading IMEI... ok IMEI: 356570063377826 Unlocking... error (0) Done with Samsung Tool PRO v.27.0 |
11-02-2016, 13:37 | #3 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 871125 Status: Offline Sonork: 1607190 Thanks Meter: 83 | N910F https://www.androidfilehost.com/?fid=24052804347848252 flash this file and then unlock...i hope this will work |
The Following 28 Users Say Thank You to aliraxa For This Useful Post: |
01-09-2017, 18:06 | #6 (permalink) | |
Junior Member Join Date: Jan 2009 Location: spain
Member: 952636 Status: Offline Sonork: chowhan Thanks Meter: 1 | Thanks, This Modem Downgrade did the trick for N910F on 6.0.1 , no Root Needed. Quote:
The Following User Says Thank You to chowhan For This Useful Post: |
04-22-2017, 14:29 | #7 (permalink) |
Freak Poster Join Date: Jul 2016 Location: bangladesh,sylhet
Member: 2599736 Status: Offline Sonork: what is this? Thanks Meter: 176 | sm-n910f 6.0.1 unlock not done have a 6.0.1 version modem files thats why unlock eror with z3x but z3x have a good system u can downgrade whole flash with modem its help for unlock . i know its not a perfect solution but sometimes its happen that u need to make it perfect now question how to unlock with 6.0.1 version without downgrading system |
The Following User Says Thank You to shishir1234 For This Useful Post: |
07-05-2017, 09:18 | #9 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: romania Age: 47
Member: 45811 Status: Offline Thanks Meter: 5 | Quote:
work very good with this modem,tks!!! | |
09-20-2017, 14:55 | #10 (permalink) | |
Freak Poster Join Date: Jun 2002
Member: 13345 Status: Offline Thanks Meter: 16 | Quote:
10-29-2017, 19:28 | #11 (permalink) |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | If Im wrong please correct me guys... but as far as I know once unlocked can be flashed with stock firmware later without any worries the "simlock back" .... actually I had never verify that coz mostly customers are happy with root-ed device ! |
11-25-2017, 13:05 | #12 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: out there
Member: 73674 Status: Offline Thanks Meter: 91 | Quote:
Operation: Unlock Selected model: SM-N910F Selected port: COM21 SAMSUNGMobileUSBSerialPort Software version: 29.9 Reading phone info... Reading IMEI... OK IMEI: 3572210612 Unlocking... error (02) Operation: Flash Selected model: SM-N910F Software version: 29.9 Searching phone and switching to flash mode... OK Operation: Flash Selected model: SM-N910F Software version: 29.9 File analysis... OK Total file size: 0x03CCA300 (60 Mb) Searching USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Sending modem.bin... OK ß CP_N910FXXU1COJ3.tar.md5 Flashing done (time - 00:00:16) Operation: Unlock Selected model: SM-N910F Selected port: COM21 SAMSUNGMobileUSBSerialPort Software version: 29.9 Reading phone info... Reading IMEI... OK IMEI: 357221061 Unlocking... OK Reseting... OK Unlock done | |
01-11-2018, 10:19 | #13 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: Turkey/ Gaziantep
Member: 833220 Status: Offline Sonork: hasokeh Thanks Meter: 16 | Quote:
The Following User Says Thank You to hasokeh For This Useful Post: |
06-19-2018, 12:22 | #14 (permalink) |
Junior Member Join Date: Sep 2011 Location: Russian
Member: 1661270 Status: Offline Sonork: 07007 Thanks Meter: 2 | Operation: Unlock Selected model: SM-N910F Selected port: COM54 SAMSUNG Mobile USB Serial Port Software version: 32.7 Reading phone info... Reading IMEI... OK IMEI: 35420********** Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.32.7 thank you fanbang, aliraxa, thanks for the file CP_N910FXXU1COJ3.tar.md5 |
