Old 04-16-2018, 05:06   #16 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 709
Originally Posted by Nile56 View Post
Nothing to loose when you get this unit and, before anything we dial code ##3424# and ......° SURPRISE! You can get Qcmm Utill so, you donít need spc/msl code.That happened to me.
Exactly what happened to me too. No Spc/Msl code required for the phone
Old 04-16-2018, 11:37   #17 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 709
Originally Posted by wirelessinfinit View Post
And you just wrote nv data and that's all?
You can NOT write the NV data with the Z3X box. You need to write an special "NV" file with "cdmaware free nv writer":
https://drive.google.com/file/d/1p2Q...U_E1IPd1Z/view
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Old 04-17-2018, 07:24   #18 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,821
Writing NV-items from a file:
Unsuccessfully written NV-items:
50155 (0xC3EB) - Access denied
Done.
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 04-26-2018, 16:38   #19 (permalink)
Member: 2510340
Thanks Meter: 8
I read the spc using gcpro after putting the combo and doing unlock gives you the spc.
Old 04-26-2018, 16:58   #20 (permalink)
Member: 2596108
Thanks Meter: 39
Why is no one addressing this. Some people are running into this when they try to write with the tool in op
Done.
Old 04-27-2018, 20:26   #21 (permalink)
Member: 2510340
Thanks Meter: 8
Friend that's what you get when you finish the writing operation correctly.
Old 04-28-2018, 00:38   #22 (permalink)
Member: 2596108
Thanks Meter: 39
Really? How come no one said this in the thread lol you can see why it's so confusing
Old 05-02-2018, 12:43   #23 (permalink)
Member: 2512574
Thanks Meter: 25
i have solution contact me free solution
Old 05-02-2018, 17:46   #24 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,821
The solution Altrady posted and itís worked 100% , if you have solution post here
Old 05-02-2018, 22:09   #25 (permalink)
Member: 2596108
Thanks Meter: 39
You mean the same solution in this thread that's also offered free?
The Following User Says Thank You to wirelessinfinit For This Useful Post:
Old 05-03-2018, 12:32   #26 (permalink)
Member: 2148129
Thanks Meter: 6
There is a solution to Permanent Unlock this phone in Bit 3 a lot time ago. Free and paid solution can found.
Old 05-03-2018, 21:17   #27 (permalink)
Member: 2749271
Thanks Meter: 2
Originally Posted by GalaxyVibe View Post
Better explained by "larez":
1. First we passed the binary combination 3
2. We read the MSL or SPC with z3x or optopus using the model j320p or g900p only in opotpus in z3x read it by its normal model
3. Then we pass the binary software 3 ql3 to be in the latest version, then in the call menu we dial ## 3424 # and put the msl we go usb senting then we select dm-moden-adb and save the configuration
4. Now we activate a serail port we search in device administrator to see what port number is with the NV Item we open it and look for the port number of the serial port and connect then we go to the writer option and pass the NVRAM and restart the cell phone and BOOM will be Unlock
Files needed
password= furqanwali
CLICK ON THE THANKS BUTTON IF THIS POST WAS HELPFUL!!
Friend how i read msl code with z3x? i dont have that option in this model. Just unlock i have 31.5.3 version.
Thanks
Old 05-03-2018, 21:55   #28 (permalink)
Member: 2282504
Thanks Meter: 39
Thanks
I got my spc or msl code from my j727p in this way. https://forum.xda-developers.com/gal...o/msl-t3628774
use method to root. https://www.youtube.com/watch?v=0yLJAmfLR-c
The Following User Says Thank You to ltindi32 For This Useful Post:
Old 05-03-2018, 22:34   #29 (permalink)
Member: 2749271
Thanks Meter: 2
Hi, i try something diferent, and i thing its easier.
Install Combination i use J727PVPU3ARA1
In combination hit IMEI and put *#0808* Select DM+ACM+ADB
Then run NV select port conect and write. Select the nv file.
Flash J727PVPU3AQJ3_SPT3AQJ3 Without the pit file.
Comb and firm downloaded from z3x files.
No need of root and no need of msl code.
The Following User Says Thank You to mordock For This Useful Post:
Old 05-04-2018, 06:05   #30 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,821
and you can enable diag via octopus box , fast and easy
The Following 2 Users Say Thank You to Mr.3. For This Useful Post:
Page generated in 0.18217 seconds with 7 queries
