Old 05-04-2018, 15:51   #31 (permalink)
Member: 2512574
Thanks Meter: 25
Originally Posted by Mr.3. View Post
The solution Altrady posted and itís worked 100% , if you have solution post here
Contact us free solution
Old 05-04-2018, 16:01   #32 (permalink)
Member: 2596108
Thanks Meter: 39
Wait how? Without combo or msl code? Can you go into detail
and you can enable diag via octopus box , fast and easy
Old 05-04-2018, 17:23   #33 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,822
Yes no need combo or msl, but you need root
select model click enable diag
Old 05-04-2018, 17:27   #34 (permalink)
Member: 2596108
Thanks Meter: 39
Ahh root is no bueno
Old 05-28-2018, 03:48   #35 (permalink)
Member: 2323265
worked 100% man u are awesome
this did what z3x and octuplus couldn't do
Old 06-08-2018, 12:47   #36 (permalink)
Member: 2508499
Question can you confirm that this works? no need for reading spc? or msl?
Originally Posted by mordock View Post
Hi, i try something diferent, and i thing its easier.
Install Combination i use J727PVPU3ARA1
In combination hit IMEI and put *#0808* Select DM+ACM+ADB
Then run NV select port conect and write. Select the nv file.
Flash J727PVPU3AQJ3_SPT3AQJ3 Without the pit file.
Comb and firm downloaded from z3x files.
No need of root and no need of msl code.
Sorry, if i'm posting this wrong it is my first time using this message board. Although most likely won't be my last... I must have done something wrong because i now can't get past the software update part in the beginning setup, no matter wifi or modem/sim... any help would be appreciated... I have a z3x box and experience. Also, i have already downloaded the nv program and the last three combination and firmware files. This ain't my first rodeo. ;-)
insomnia
Old 06-10-2018, 02:06   #37 (permalink)
Member: 2508499
Cool Once That is written to the NV is there any way to undo without a backup file?
Originally Posted by insomnia79 View Post
Sorry, if i'm posting this wrong it is my first time using this message board. Although most likely won't be my last... I must have done something wrong because i now can't get past the software update part in the beginning setup, no matter wifi or modem-sim... any help would be appreciated... I have a z3x box and experience. Also, i have already downloaded the nv program and the last three combination and firmware files. This ain't my first rodeo. ;-)
insomnia
OK, update I have gotten the system back, it'll do a custom recovery and ROm, root, the whole 9 yards even unlocking software I run on it says, success.... I have repaired everything I could with my z3x box.. But still that NV file must have done something that none of that fixes... My T-Mobile nor Verizon Sims will work. Verizon is in ROAM constantly and T-Mobile is invalid sim... I just did a white J727P and it didn't give me near the disaster that this little bugga did! HELP.... Pls.... Thanks in advance. I would like to learn more about the intricies of this area of knowledge... I worked in the field as a penetration tester-networking Specialist.. I can script, code, tear **** apart at its fullest... Is there any groups that are looking for help, I've been working in these types of areas for 20 years... Mainly in the development part of exploits themselves. Anyway, Holla!😇
Old 06-13-2018, 12:48   #38 (permalink)
Member: 1784928
Sonork: cuto
Originally Posted by gsm_service4u View Post
Combo and GCPro Sprint unlock also works for reading spc
friend the code is no longer working if you can help me thank you
Old 06-13-2018, 23:17   #39 (permalink)
eyasin's Avatar
Member: 885387
Sonork: 100.1597540
Thanks Meter: 59
I have full solution
And I done many pics
Max 5 min work
Old 06-14-2018, 04:19   #40 (permalink)
Member: 162707
Thanks Meter: 57
Max 5 min work
hello what is the solution please
Old 06-19-2018, 23:48   #41 (permalink)
Member: 2179862
Thanks Meter: 8
No luck reading SPC after flash CombFile throug Z3X.
Writing AT RIL... OK
Initialization AT RIL... error (2)
Done with Samsung Tool PRO v.32.7
Any suggestion?
Old 06-22-2018, 03:51   #42 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,822
Any suggestion?
HELP: Samsung Galaxy J7 Perx SM-J727P Sprint/Boost J727PVPU3AQJ3 Binary 3 UNLOCK Z3X
Old Yesterday, 20:18   #43 (permalink)
Member: 1693475
Initialization at RIL... error (2)
In Z3x, while trying to read MSL in step 2 below, Z3X errors out and says 'Initialization at RIL... error (2). What's wrong ?
________________
Originally Posted by GalaxyVibe View Post
Better explained by "larez":
1. First we passed the binary combination 3
2. We read the MSL or SPC with z3x or optopus using the model j320p or g900p only in opotpus in z3x read it by its normal model
3. Then we pass the binary software 3 ql3 to be in the latest version, then in the call menu we dial ## 3424 # and put the msl we go usb senting then we select dm-moden-adb and save the configuration
4. Now we activate a serail port we search in device administrator to see what port number is with the NV Item we open it and look for the port number of the serial port and connect then we go to the writer option and pass the NVRAM and restart the cell phone and BOOM will be Unlock
Files needed
https://drive.google.com/file/d/1p2Q...U_E1IPd1Z/view
password= furqanwali
___________
Old Today, 03:49   #44 (permalink)
chezral's Avatar
Member: 203715
Thanks Meter: 226
Thx for help guys. Here are my slightly different steps:
1- flash this file for root : Samsung J7 Perx J727P Nougat 7.0 Tested Root File | Samsung FRP
2- install superSU apk
3- install idone/GT v3.15 apk (had found it on this forum a while ago)
4- open GT app and scroll done and click 'IOTHIDDENMENU'
5- select usb settings
6- select DM+MODEM+ADB
7- open Z3X select J727p and select unlock, this show [Initialization at RIL... error]
8- use NV tool from this post to write nv, this show successful, but also shows write nv failed.
9- restart the phone and now it's unlocked!
So you just need to root and use GalaxyTools 3.15 to enable diag, then unlock. Not sure if Z3X or the nv is what did the unlock, you can try one and see which does the unlock, but despite error phone will be unlocked!
combo not needed or msl.
Page generated in 0.20090 seconds with 7 queries
