10-08-2019, 16:02 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: SWEDEN
Member: 683086 Status: Offline Thanks Meter: 15 | cant unlock s9 any one can help to unlock this phone Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 9 PDA version: G960FXXS6CSH5 CSC version: G960FCKH6CSH1 Phone version: G960FXXU6CSGD Product code: SM-G960FZKDHTS CSC country code: Sweden CSC sales code: HTS Phone SN: R58K32K5PJL IMEI: 35717109093xxxx HW version: MP 0.900 RF cal date: 20180310 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2019-09-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.37.0 |
10-08-2019, 16:47 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
Sent from my SM-N950F using Tapatalk | |
10-08-2019, 16:54 | #3 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
To have the combination binary 6 modem for g960F you need to download the combination, then with the 7zip software you extract the modem from the combination and rename it in tar format and then install it on the phone. COMBINATION_OXM_FA80_G960FXXU6ASG2 Download: https://mega.nz/#!80dmHSxA!a6jkI7Sde...FoGcmkuWkCgeaU If the method of unlocking with the modem combination installed with z3x should not be successful and you have other boxes or tools you can try with those with the combination modem or the stock firmware moden to unlock the network, in case you don't even succeed with other tools or boxes at the moment there is no solution and you have to wait for an update to support the release of the network for g960F | |
The Following User Says Thank You to amleto90 For This Useful Post: |
10-09-2019, 11:18 | #4 (permalink) | |
Member: 683086 Status: Offline Thanks Meter: 15 | Quote:
UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960F Software version: 37.0 Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 8.0.0 PDA version: FA80_G960FXXU6ASG2 CSC version: Phone version: G960FXXU6ASG5 Product code: SM-G960FZKDHTS CSC country code: CSC sales code: Phone SN: R58K32K5PJL IMEI: 35717109093xxxx HW version: MP 0.900 RF cal date: 20180310 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2018-01-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... Combination firmware detected, please flash user firmware Done with Samsung Tool PRO v.37.0 | |
10-09-2019, 11:41 | #5 (permalink) | |
10-10-2019, 12:55 | #6 (permalink) | |
Ballance: 35 crd. You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 9 PDA version: G960FXXU6CSG8 CSC version: G960FOXM6CSG5 Phone version: G960FXXU6ASG5 Product code: SM-G960FZKDHTS CSC country code: Germany CSC sales code: DBT Phone SN: R58K32K5PJL IMEI: 35717109093xxxx HW version: MP 0.900 RF cal date: 20180310 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2019-07-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 25749513 NET lock: 38385305 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.37.0 solv flash phone with firmwear from z3x server | |
