-   Z3X-Team Products (http://forum.gsmhosting.com/vbb/f453/)
-   -   Help Unlock Samsung T999V ?? (http://forum.gsmhosting.com/vbb/f453/help-unlock-samsung-t999v-1697305/)
07865 08-07-2013 09:57
Hi guys , I got a t999v Samsung for 2 weeks now and I have tried everything to unlock it
Selected model: T999V
Selected port: COM10 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Build: M8960A-AAAANAZM-1.0.443072
Done with Samsung Tool v.15.2
Reading security... error access denied
I have tried flashing it with
\T999VVLDMF2_T999VYVLDMF2\KIES_HOME_T999VVLDMF2_T9 99VYVLDMF2_CL1189444_REV04_user_low_ship.tar.md5
and its still not unlocking
its on 4.1.2 software please help guys customer taking phone today ???
gsmnsd 08-07-2013 10:10
just downgrade your phone and try again
07865 08-07-2013 10:17
to what software which one can I find ?
thanks for helping
artemis17 08-07-2013 15:19
thanks for helping
download this one and flash it to your phone... you may need to do a factory reset to the phone after downgrading. You then should have no issue unlocking and you can then upgrade the software again
Hotfile.com: One click file hosting: T999VVLALH2_T999VYVLALH2_MCT.zip
07865 08-08-2013 11:40
hi mate now stuck on Samsung logo ?
07865 08-08-2013 11:45
anybody smart enough to solve this ? :D only got 3 hours left with phone before customer takes it
I have flashed above software
now its stuck in Samsung logo ?
gsmnsd 08-08-2013 11:50
try to wipe cache data by recovery mode your problem will be solved ;)
07865 08-08-2013 11:57
how mate ?? odin ???
07865 08-08-2013 11:59
wiped still not loading ??
07865 08-08-2013 13:10
Done thanks guys
had to reset data
cheers
rumisunqu 10-21-2013 22:55
mates i have this
failed when i try to read codes or unlock direct
Plataforma: Samsung Android
Puerto seleccionado: COM298
Modelo seleccionado: SGH-T999
Modo: Normal
Modelo del teléfono: SGH-T999
Fecha de creación del firmware: May 19 2013
Tiempo de compilación del firmware: 23:00:00
Fecha de salida del firmware: Jun 21 2013
Tiempo de salida del firmware: 22:59:07
IMEI del teléfono: 353102-05-015351-6
Versión del SW: M8960A-AAAANAZM-1.0.443072
Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere…
Reading security failed
La lectura de códigos ha sido fallada
bhernz 12-14-2013 04:31
kindly upload to another link like 4shred.com or mediafire.com.. cannot download the file..
rumisunqu 03-12-2014 21:41
after flash all went ok
thx for advice
Selected port: COM20 Z3X BOX Serial Port
File analysis... OK
Total file size: 0x48164288
Searching USB Flash Interface... detected COM13
Setup connection... OK
Reading PIT from phone... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\T999V_12-3-2014_17-3-7.pit
Sending sbl2.mbn... OK
Sending sbl3.mbn... OK
Sending aboot.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending NON-HLOS.bin... OK
Sending cache.img.ext4... OK
Flashing done (time - 00:06:58)
Done with Samsung Tool v.17.1
Reading phone info... no answer from phone
Selected port: COM216 SAMSUNG Mobile USB Serial Port
Build: M8960A-AAAANAZM-1.0.061009
Reading security... OK
Writing security... OK
Reseting...
Unlock done
Repairing IMEI... OK
Reseting... OK
Repair done
Selected model: S6810L
Searching Samsung modem... not found
File analysis... OK
Reseting...
Unlock done
Reseting... OK
Repair done
File analysis... OK
Reseting...
Unlock done
Reseting... OK
Repair done
Masaker514 06-28-2014 13:06
I need some help I unlocked T999v everything said pass but it kept showing no service. Baseband is there so is the IMEI any help please.
Beto48 06-28-2014 13:27
Check IMEI, with those version of Samsung Tools of z3x most unlocks clean te IMEI number to 00 check it.
Page generated in 0.33866 seconds with 5 queries
