12-07-2014, 03:32 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2306221 Status: Offline Thanks Meter: 0 | help! Unresponsive touch. Software or hardware issue? while im using my phone, I've had to change my charger , then after I put the charger(charger of my other android) my phone stock-up , so I have to remove the battery to let it restart, then I came up with a boot-loop at samsung logo, then I have to use recovery mode but unfortunately I can't access the recovery mode. so I use download mode(odin, I flashed firmware 4.4 kitkat then do hard reset) it solves the boot-loop and I reach the start-up configuring page. but the problem now is the "touch don't work anymore" I really don't have any ideas on how to root at start(where I flash firmware to fix the bootloop) I already downloaded lots of files like -recovery-clockwork-6.0.4.6-serrano3gxx -CF-Auto-Root-serrano3g-serrano3gub-gti9190 -I9190XXUCNG1_I9190SERCNG1_I9190XXUCNG1_HOME -Odin3 v3.09 -I9190XXUBNB2_I9190YXEBNB1_I9190XXUBNB2_HOME -S4Mini_RootKit_v2 -CARBON-JB-UNOFFICIAL-20131105-2036-serrano3gxx and I randomely flash them or unzip some of them if needed depends on the procedure, but I end up having a boot loop again when I change the first firmware that I had flash which is the kitkat and have to flash again to kitkat to fix the boot-loop but I ended up at starting configuration page where my touch won't work but other keys are working. done with doing clear cache/clear data, hard reset, soft reset. help me pls. Thank you in advance for the support and help! |
