12-02-2018, 23:59 | #1 (permalink) |
Major Poster Join Date: May 2016
Member: 2580111 Status: Offline Thanks Meter: 7 | help: USA firmwares for s8 and +, s9 and [Answered] In that case... if the same for g950u1, g955u and u1, g960u and u1??? I appreciate the help... thanks... |
12-04-2018, 00:16 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
12-18-2018, 04:36 | #4 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
You're better off flashing the unbranded "U1" firmware which auto-configures itself based on the sim card inserted. Works better and smoother than the carrier branded versions. | |
The Following User Says Thank You to BillA For This Useful Post: |
12-19-2018, 01:04 | #6 (permalink) | |
Yes, it works fine even with locked bootloader, the only thing you have to match is the firmware revision (4th digit from the right), and use the patched Odin (below). Out of habbit I also select the PIT file which can be extracted from the CSC (non-home file) and under Options select Erase Nand. It works great, totally unbranded which opens up the Verizon/Sprint bands too if it's an unlocked gsm. Samsung_Odin_v3.13.1_Patched.ZIP https://www.androidfilehost.com/?fid=673956719939831735 And here are the latest G950U1 firmwares (top ones are the latest, make sure to download the "XAA" version only!) https://updato.com/firmware-archive-...r=desc&exact=1 Last edited by BillA; 12-19-2018 at 01:11. | |
