GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Z3X-Team Products (https://forum.gsmhosting.com/vbb/f453/)
-   -   hi z3x team Samsung chat e2222 flash problem (https://forum.gsmhosting.com/vbb/f453/hi-z3x-team-samsung-chat-e2222-flash-problem-1379540/)
T0T0 11-11-2011 10:30
hi team i have samsung e2222 password problem e try unlock, reset the phone but same so i decided to flash phone i download support area there's only one file available.... this file E2222XEKD4
the problem now is after flash no menu pls help.....
and the password still not remove.....
sagez gsm1 03-03-2012 23:15
Originally Posted by Vero (Post 8201777)
Same problem here, the menus are bad after flash with Z3X.
How fix it ?
Check to see...
http://forum.gsmhosting.com/vbb/f453...flash-1417156/
http://forum.gsmhosting.com/vbb/f453...inker-1384616/
Vero 03-03-2012 23:17
Repaired with original Flasher (Flash Loader 7.4.7), now the menus are ok.
Thank you anyway.
Regards.
alex999_ 03-04-2012 12:15
*2767*3855# after flash and menu - ok.
anil.prajapati 09-17-2012 08:01
Firmware Update Process:
- First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed
- Power on the phone and connect USB cable to it and to PC to let Windows install its drivers.
- Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers.
- Run the E2222 Ch@t Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe
- Click SET MODEL button and select: E2222_TEXTO_Setting_v00.mdl
- For Application Binary File select: E2222xx.ptt
- For Tfs file select: E2222xxxxx.tfs
- For CSC file select: E2222Oxxxxx.csc
- Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers.
- Disconnect the phone after DFU drivers installed.
- Click START button and reconnect USB cable to phone while pressing Q + A keys.
- The program will detect it and start the Update Process so wait till all is DONE.
- Disconnect the phone and turn it on then do Full reset: *2767*3855#
$sumitgsm$ 02-12-2013 06:06
e2222 flash fail
elected model: E2222
Selected com port: COM12
Selected speed port: 921600
Press "volume down" + "lock" and connect USB cable to phone
Connect to control pipe... OK
Processor ID -> 0A34
Sending loader... OK
Connect to write pipe... FAIL
Send loaders - fail
Elapsed time: 11 second, sw ver: 3.5.0040
monday2 03-09-2013 12:17
no volume so what will i do now solution pls
himanshu taldar 03-09-2013 12:20
Press Q+W without Battery and connect usb cable.
suraj9860607689 07-14-2013 10:28
Its Working For me :)
phone2world 08-17-2013 16:40
Selected model: E2222
Selected com port: COM6
Connect to write pipe... OK
Connect to read pipe... OK
Sending part LCDACT:
Erasing... OK
Sending... OK
Sending part MAIN:
Erasing... OK
Sending... OK
Sending part DSP:
Erasing... OK
Sending... OK
Sending part ROOT:
Erasing... OK
Sending... OK
Sending boot sector:
Erasing... OK
Sending... OK
Sending TFS... OK
Sending CSC... OK
Download - ok
Elapsed time: 313 second, sw ver: 3.5.0040
gsmline 05-31-2014 08:20
flash loader ...7.4.7..:
log:
Waiting for board reset
device connected to port 2
err 108 - error during communication initialization (in initseq)
start avaible now
slot freed for new download
I do not want to program, Z3x does flash but the phone blink
yogyaa 06-18-2014 14:22
it's really working....
press 'Q' + 'W' and connect usb cable without battery..
here is log..
Selected com port: COM3
Erasing... OK
Sending... OK
Sending part MAIN:
Erasing... OK
Sending... OK
Sending part DSP:
Erasing... OK
Sending... OK
Sending part ROOT:
Erasing... OK
Sending... OK
Erasing... OK
Sending... OK
Sending TFS... OK
Sending CSC... OK
Download - ok
Elapsed time: 406 second, sw ver: 3.5.0040
bala007 03-27-2015 10:35
thanks bro its work for me q+w
prasad0225 06-24-2016 06:00
its work for me q+w thank you
Page generated in 0.15090 seconds with 6 queries
