Unlock Server
Old 11-11-2011, 09:30   #1 (permalink)
Member: 572549
hi z3x team Samsung chat e2222 flash problem
hi team i have samsung e2222 password problem e try unlock, reset the phone but same so i decided to flash phone i download support area there's only one file available.... this file E2222XEKD4
the problem now is after flash no menu pls help.....
and the password still not remove.....
Old 03-03-2012, 21:39   #2 (permalink)
Member: 185279
Red face
Same problem here, the menus are bad after flash with Z3X.
How fix it ?
Old 03-03-2012, 22:15   #3 (permalink)
sagez gsm1's Avatar
Member: 1474571
Sonork: 100.1614377
How fix it ?
Check to see...
samsung E2222 sucessfully flash.........
successfull flash e2222 (Blinker)
Old 03-03-2012, 22:17   #4 (permalink)
Member: 185279
Repaired with original Flasher (Flash Loader 7.4.7), now the menus are ok.
Thank you anyway.
Regards.
Old 03-04-2012, 11:15   #5 (permalink)
Member: 561932
*2767*3855# after flash and menu - ok.
Old 09-17-2012, 08:01   #6 (permalink)
anil.prajapati's Avatar
Member: 1642979
Sonork: 100.1613407
Firmware Update Process:
- First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed
- Power on the phone and connect USB cable to it and to PC to let Windows install its drivers.
- Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers.
- Run the E2222 Ch@t Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe
- Click SET MODEL button and select: E2222_TEXTO_Setting_v00.mdl
- For Application Binary File select: E2222xx.ptt
- For Tfs file select: E2222xxxxx.tfs
- For CSC file select: E2222Oxxxxx.csc
- Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers.
- Disconnect the phone after DFU drivers installed.
- Click START button and reconnect USB cable to phone while pressing Q + A keys.
- The program will detect it and start the Update Process so wait till all is DONE.
- Disconnect the phone and turn it on then do Full reset: *2767*3855#
Old 02-12-2013, 05:06   #7 (permalink)
Member: 1539798
Sonork: 12345
e2222 flash fail
elected model: E2222
Selected com port: COM12
Selected speed port: 921600
Press "volume down" + "lock" and connect USB cable to phone
Connect to control pipe... OK
Processor ID -> 0A34
Sending loader... OK
Connect to write pipe... FAIL
Send loaders - fail
Elapsed time: 11 second, sw ver: 3.5.0040
Old 03-09-2013, 11:17   #8 (permalink)
Member: 1853385
Sonork: ebong
no volume so what will i do now solution pls
Old 03-09-2013, 11:20   #9 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Press Q+W without Battery and connect usb cable.
The Following User Says Thank You to himanshu taldar For This Useful Post:
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 1.25841 seconds with 11 queries
