how to enter code unlock lg gs 290 with 2945 # * xxx # impossible to enter the menu to unlock gs290 please help me |
try without sim type 2945#*510#................ |
note: lg gs290 vodafone spain |
reset phon after type 2945#*510#. omar |
Try to use following codes: 2945#*290# or 2945#*71002#. You can rebuild security zone after you get NCK. Phone must be powered on , 1. Click Rebuild security. 2. Select Proper port 3. Set "Phone need login" , select NCK 4. Fill IMEI and click Repair. Sec area will be rebuilded and locks go away |
[QUOTE=NoName®;5850227]Try to use following codes: 2945#*290# or 2945#*71002#. You can rebuild security zone after you get NCK. Phone must be powered on , 1. Click Rebuild security. 2. Select Proper port 3. Set "Phone need login" , select NCK 4. Fill IMEI and click Repair. Sec area will be rebuilded and locks go away[/QUOT THANK YOU Sir, with this 2945 # * 290 # FIXED THANKS AGAIN |
thx mr NoName for you help |
thanks mr samirho ............ |
Hi what is entire procedure to unlock LG GS290 please? Thank you |
thanks to oll 0gsm forums |
[QUOTE=samirho;5851682] Quote:
this method work good thankx for it sir |
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_04082 010_213637.eep Analising EEPROM... Phone IMEI:359289038884660 Unlock codes: NCK[0]: 2566139720973890 (LOCKED) Finished in 4 seconds Reading EEPROM Sending SEC pack... Analising EEPROM... Phone IMEI:359289038884660 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*XXX# ,where XXX are model digits to enter unlock menu 3. Enter one of this code(s): NCK[0]: 2566139720973890 (LOCKED) NCK[1]: 7073188401662594 (NS) NCK[2]: 1252490772027658 (SP) NCK[3]: 3905087341478532 (CP) Finished in 4 seconds thanks....... its working... |
Hello,i m trying to unlock LG GS290,but no success! Reading phone information ( must be powered ON! Phone platform:INFINEON Phone IMEI:35928903878317700 Phone S/N:35928903878317700 Phone SW VER.:GS290AT-01-V10g-284-03-APR-01-2010+0 Phone HW VER.:1.0 Phone LCD Revision:CDR NOT SUPPORT Phone Camera Revision:AMR NOT SUPPORT Bluetooth Adress:800000000000 Net Lock Conf:"1","284,03F,FFFFFFFF,FFFFFFFF,FF" SIM Lock Conf:"1","284,03F,FFFFFFFF,FFFFFFFF,FF" Battery Voltage:4.2V Done! Repairing IMEI... , phone must be powered on! Current IMEI:35928903878317700 Setting up secure mode! Writing new IMEI:35928903878317 Result is: this "RESULT IS:" staying 10 minutes and nothing happened! |
GS290 unlock With code 2945#*290# (UNLOCK SIM menu), when press "NETWORK UNLOCK" - result is : "Not Available" ! Please help! Thanks! |
how du get those codes??? help me plzzz...i maybe have blonde brains but cant understand how ur fone can read something, ??? help me, i always get anything but this time i just dont get it |
