Old 10-17-2010, 07:39   #1 (permalink)
Member: 1119248
Sonork: 000000000000000000000000
Thanks Meter: 130
how to flash c3303 ?
plz tell me how flash c3303
z3x box no hilite firmware write option
Old 10-17-2010, 07:58   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,485
not supported for flashing yet.
The Following User Says Thank You to blang For This Useful Post:
Old 12-31-2010, 11:22   #3 (permalink)
Member: 776810
Sonork: 100.1627706
Thanks Meter: 15
Question user lock
how to reset user lock code............. which cable use in c3303
The Following User Says Thank You to firose4u For This Useful Post:
Old 05-27-2011, 08:00   #4 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Autoignition cable for c3303
The Following User Says Thank You to rajeshchiyyan For This Useful Post:
Old 05-30-2011, 10:12   #5 (permalink)
trust4eve83's Avatar
Member: 1269056
Thanks Meter: 1,034
Updating Samsung c3303 Champ Flash/Firmware
The Following User Says Thank You to trust4eve83 For This Useful Post:
Old 05-30-2011, 10:23   #6 (permalink)
Member: 1269056
Thanks Meter: 1,034
Arrow Updating Samsung c3303 Champ Flash/Firmware
Prepare the Phone Driver for Flashing.
1. Turn OFF Phone.
2. Connect MicroUSB to Champ.
3. Press Volume Down + Lock key then connect USB Cable to PC
4. Install driver (Driver can be found on C3300K_Flash_loader_7.4.4_SSG_v0.5 folder, 52xdfu)(Manual install it using device manager)
When installed, get ready.
Re flashing
1. Run Flash loader 7.4.4_SSG_v0.5.exe
2. Click SET MODEL -> Select C3300_LIBRE_Setting_v02.mdl
6. Click Start
7. Turn OFF Phone.
8. Connect MicroUSB to Champ.
9. Press Volume Down + Lock key then connect USB Cable to PC
10. Wait the flashing finished.
(During the Flashing, your phone is off, then when the flashing is finish, you can see the your phone is charging.
11. Remove from USB. Turn on the Phone, Check if success,
-if failed, try nyu ulit ang mga steps.
Good Luck.
Do at your own risk. Not my responsibility for the Possible Damage can be made to your Phone
direct download link
1. Flasher: http://www.4shared.com/file/PNYp0EsM/C3303KJPJI2.html pass: 'www.gem-flash.com'
2. Firmware:
http://www.4shared.com/file/8S8zLiSd/C33...SG_v0.html
3. MicroUSB
4. C3303k Samsung Champ Phone
5. Prepare Phone Driver
enjoyyyyy
mohsin from south africa
The Following 5 Users Say Thank You to trust4eve83 For This Useful Post:
Old 10-01-2011, 04:51   #7 (permalink)
Member: 459869
Thanks Meter: 46
Exclamation
but my c3303k i face with this error flashing problem, please help & advice
Old 10-01-2011, 05:05   #8 (permalink)
.::SOLUTION::.'s Avatar
Member: 1653223
Sonork: 100.1619309
Thanks Meter: 142
now we can flash C3303 with z3x
update your software
z3x support c3303 flash
The Following User Says Thank You to .::SOLUTION::. For This Useful Post:
Old 10-27-2011, 13:05   #9 (permalink)
Member: 1342044
Thanks Meter: 42
file password ..........................................??????
Old 11-08-2011, 10:03   #10 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,835
Here C3303i Firmware
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 02-06-2012, 22:04   #11 (permalink)
khokonhajigonj's Avatar
Member: 771795
Sonork: 771795
Thanks Meter: 120
i cant solve usb d/l mood problem when i connect it by press vol plus and lock key it connect then disconnect from download mode and blinking.
Old 07-24-2012, 01:40   #12 (permalink)
Member: 1760941
Sonork: 100:1616842
Any new firmwares for C3303K?
Can anyone explain me the different between firmwares C3303KJPJI2 & C3303I-DXKB1?
I am a newbie. So, don't get mad at me if it was a stupid question.
Old 07-24-2012, 01:44   #13 (permalink)
yogyaphone.'s Avatar
Member: 1786327
Sonork: 100.1621394
Thanks Meter: 58
See your phone back sticker. It is C3303K or C3303I.
Wrong files will make the phone not working, can be repaired by flashing with correct firmware.
C3303K-JP-JI2
Phone type - Region - Release date / version
The Following User Says Thank You to yogyaphone. For This Useful Post:
Old 07-24-2012, 13:16   #14 (permalink)
Member: 1760941
Sonork: 100:1616842
C3303K-JP-JI2
Thank you very much for the explanation.
I am from Sri Lanka.
For which version should I go for?
Will the European versions work for me or Do I have to go for any Asian version?
(I searched for Sri Lankan version, but there was nothing)
Old 08-02-2012, 15:54   #15 (permalink)
ASIEDU ANNOR's Avatar
Member: 510345
Thanks Meter: 30
c3330 dead flashing
i have c3330 any software for flashing? it died when flashing with Z3x box
1. Turn OFF Phone.
Re flashing
6. Click Start
7. Turn OFF Phone.
Good Luck.
2. Firmware:
3. MicroUSB
enjoyyyyy
The Following User Says Thank You to ASIEDU ANNOR For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.50639 seconds with 9 queries
