how to flash c3322 with z3x please are there any way to flash c3322 via z3x please !!!! |
iam also same problem///////////////// |
i tried for 6 days to connect c3222 with z3x but not success .........i dont understand how can i flash or unlock the phone?is it usb driver problem or what?i am going to be mad......if my problem will be solved in 2 days i will throw the box...... |
Mate its flashing is not supported flash with its Flasher: http://www.fileserve.com/file/vHjrfU..._v0.1_Lite.rar WBR |
i even cant read info brother.................. |
Here is the Manual how to Flash : 1- First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed 2- Power on the phone and connect USB cable to it and to PC to let Windows install its drivers. 3- Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers. 4- Run the C3322 Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe 5- Click SET MODEL button and select: C3322_LAKOTA_Setting_v00.mdl 6- For Application Binary File select:C3322xx.ptt 7- For Tfs file select: C3322xxxxx.tfs 8- For CSC file select:C3322xxxxx.csc 9- Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers. 10- Disconnect the phone after DFU drivers installed. 11- Click START button and reconnect USB cable to phone while pressing Q + A keys. 12- The program will detect it and start the Update Process so wait till all is DONE. 13- Disconnect the phone and turn it on then do Full reset: *2767*3855# WBR |
Mate use Micro URT Cable(C3303K RJ45 cable) connect phone with battery and press power or change to Flash mode from Setting model and use USB cable but first you have install drivers and click on Read INFO than Press "volume down" + "lock" and connect USB cable to phone. WBR |
u mean i have to use two cable? |
where is volume down in this phone !!!????? |
No everyone is available for you you can use |
i made big mistake---i flashed the phone via ufs so the pc cant recognised the phone how can i revive it .... |
WBR |
Still then i am not clear how to read info from c3222 using z3x....... |
Click on Read Info and connect USB cable to phone while pressing Q + A keys. WBR |
what a joke???????????//evry time i asked about the problem i am getting new way to press keys......i am confused that actually which keys i have to press?have u ever done this solution or not? |
